Pausing the simulation and change the project file while running
Hello everyone,
I would like to know if it is possible in OGS to edit the simulation while running it.
Or in other words, is it possible to run a project file and model, initialized with the results of a previous run?
I started the setup with the maximum permeability value of 10e-16 due to the divergence of the model. Now at some points I want to decrease it to the real number which is 10e-21 in max.
How should I do that?
Regards
the OGS wording for that is simulation “restart”. Basically you’d have to start the second simulation with a result mesh of the first simulation as first <mesh> and use MeshNode parameters for the initial conditions of all primary variables.
If mechanics is involved you might have to remove <initial_stress>. We have several examples of the features in our test suite:
$ find Tests/Data/ -iname '*restart*.prj' -o -iname '*restart*.xml'
Tests/Data/Mechanics/Ehlers/MFront/square_1e1_2_matIDs_restart.prj
Tests/Data/Mechanics/InitialStates/equilibrium_restart.prj
Tests/Data/PhaseField/surfing/surfing_restart.xml
Tests/Data/RichardsMechanics/LiakopoulosHM/liakopoulos_restart.xml
The XML patches illustrate what you’d need to do, e.g. Tests/Data/RichardsMechanics/LiakopoulosHM/liakopoulos_restart.xml:
<?xml version='1.0' encoding='ISO-8859-1'?>
<OpenGeoSysProjectDiff base_file="liakopoulos.prj">
    <replace sel="/*/meshes/mesh[1]/text()">liakopoulos_t_600.vtu</replace>
    <remove sel="/*/processes/process/initial_stress" />
    <replace sel="/*/time_loop/processes/process/time_stepping/t_initial/text()">600</replace>
    <!-- optional -->
    <remove sel="/*/time_loop/processes/process/time_stepping/timesteps" />
    <!-- optional -->
    <add sel="/*/time_loop/processes/process/time_stepping">
        <timesteps>
            <pair>
                <repeat>6</repeat>
                <delta_t>100</delta_t>
            </pair>
        </timesteps>
    </add>
    <!-- optional -->
    <replace sel="/*/time_loop/output/prefix/text()">liakopoulos_restart</replace>
    <!-- optional -->
    <replace sel="/*/time_loop/output/fixed_output_times/text()">1200 2400 4800 6000 7200</replace>
    <remove sel="/*/parameters/parameter[name=&quot;Initial_stress&quot;]" />
    <remove sel="/*/parameters/parameter[name=&quot;displacement_ic&quot;]" />
    <add sel="/*/parameters">
        <parameter>
            <name>displacement_ic</name>
            <type>MeshNode</type>
            <field_name>displacement</field_name>
        </parameter>
    </add>
    <remove sel="/*/parameters/parameter[name=&quot;pressure_ic&quot;]" />
        <parameter>
            <name>pressure_ic</name>
            <field_name>pressure</field_name>
        </parameter>
    </add>
</OpenGeoSysProjectDiff>
AFAIK we don’t have good documentation on restart.
You might want to try restart from OGSTools, though its implementation might be incomplete, but might work for your use case.
