I am currently performing simulations of a simplified geothermal doublet system consisting of a reservoir and a single fracture.
I am trying to investigate the effect of variations in the aperture/permeability of the fracture, however I am not sure if my implementation is correct because my results do not seem to make sense.
I ran one simulation with no fracture present as a base case. Then, using the relationship permeability, k = a^2/12 (where a is the hydraulic aperture), I ran simulations with 5 values for permeability and the corresponding aperture. I expected that as the fracture permeability decreases toward that of the matrix, the production temperature curves would also shift toward the base case of no fracture. All other variables were kept the same, however when I looked at the temperature curves, they all plotted on basically the same line.
I attached the plot. The matrix case is the dark blue line and all other values show very little variation although the permeability varies over 5 orders of magnitude. I also attached an example of one of the .mmp files because maybe there is something that I am missing.
Ariel
res4_pt3.mmp (638 Bytes)
From my understanding, the aperture of the fracture is set to $GEOMETRY_AREA in the .mmp file and the fracture permeability set to the keyword $PERMEABILITY_TENSOR.
The .mmp file looks ok. Have you checked fluid velocity in the fracture while varying the permeability?
n
On 06/26/2016 09:10 PM, Ariel Thomas wrote:
Ariel
Groups "ogs-users" group.
an email to [email protected]
<mailto:[email protected]>.
Norihiro Watanabe, Dr.-Ing.
Wissenschaftler
[email protected] / http://www.ufz.de
Telefon +49 341 235 1806
I did not check the velocities but I can …I only output the ELE velocities for the base case and for the others I was mainly interested in temperature. I tried to output the velocity at the monitor point as well but this output file returned no values.
I performed similar test with high permeability. In this case I considered several values of permeability log normally distributed around the mean, 8.33e-10. I saw the expected variation in the production profile as can be seen in the attached plot…(blue line is the matrix case). However the same test for a mean of 8.33e-12 showed no spread. I ran around 50 simulations with varying values around the mean and they all plotted on the same line…
Is there some limiting case when the fracture permeability is too close to the medium permeability?
On Monday, June 27, 2016 at 8:03:51 AM UTC+2, Norihiro Watanabe wrote:
n
Ariel
Groups “ogs-users” group.
mailto:[email protected].
Wissenschaftler
Unfortunately the velocity output at particular points is not supported or not reliable in OGS. I normally calculate it from the element velocity using ParaView (extract only fracture elements and then apply "Cell data to point data" filter to get velocity in fractures).
Concerning the temperature breakthrough curve, you will see the fracture permeability influence on it only when heat transport is dominated by advection along the fracture. If flow velocity along the fracture is not sufficiently high, heat conduction in surrounding rocks becomes dominant and you will see no effects with varying the fracture permeability. Heat conduction gets more influence, e.g. when permeability in the fracture is not so high compared to the rock permeability, or the fracture aperture is too small, or thermal conductivity of the rock is high. So if you lower the rock permeability or the rock thermal conductivity, you should be able to see some variations even for a mean of 8.33e-12.
Nori
On 27/06/16 15:34, Ariel Thomas wrote:
I did not check the velocities but I can ..I only output the ELE
production profile as can be seen in the attached plot..(blue line is
and they all plotted on the same line..
n
> Hello,
doublet
sense.
to the
fracture.
at the
other
over
> Cheers,
> Ariel
send
> an email to ogs-users+...@googlegroups.com <javascript:>
> <mailto:ogs-users+...@googlegroups.com <javascript:>>.
<https://groups.google.com/d/optout>\.
Wissenschaftler
norihiro...@ufz.de <javascript:> / http://www.ufz.de
[email protected] / www.ufz.de
Administrativer Geschäftsführer: N.N.
Ahh yes that makes sense, I was thinking something along those lines but your articulated much better than I had it in my mind.
Thank you very much.
“Cell data to point data” filter to get velocity in fractures).
Nori
n
> Hello,
doublet
sense.
to the
fracture.
at the
other
over
> Cheers,
> Ariel
send
> an email to [email protected] <javascript:>
> <mailto:[email protected] <javascript:>>.
> For more options, visit [https://groups.google.com/d/optout](https://groups.google.com/d/optout)
<[https://groups.google.com/d/optout](https://groups.google.com/d/optout)>.
Wissenschaftler
[email protected] <javascript:> / [http://www.ufz.de](http://www.ufz.de)
