Hello,all! I am a initial leaner wondering to know more about the OGS.I am learning how to run the OGS with the phase-field method recently.
When i using the OGS 6.30 to run beam3d.prj published in the ThermoMechanicalPhaseField floder, The input files are available here
https://gitlab.opengeosys.org/ogs/ogs/-/blob/master/Tests/Data/ThermoMechanicalPhaseField/beam3d.prj
But, it is showing error message as follows:
Error while parsing XML file `D:\OGS软件\ogs-data-6.3.0\ThermoMechanicalPhaseField\beam3d’ at line 0: cannot open file. at ConfigTreeUtil.cpp, line 67
Your kind help and suggestion are much appreciated.
