Hello,all! I am learning how to run the OGS with the phase-field method recently.
When i using the OGS 6.3.2 to run beam3d_stag_1pcs.prj published in the PhaseField floder, i can’t get the output results after running the prj. file.The input files are available here
[Files · master · ogs / ogs · GitLab]
It is showing two warning messages as follows:
The first one is,“Consider switching from mesh and geometry input to multiple meshes input. See https://www.opengeosys.org/docs/tools/model-preparation/constructmeshesfromgeometry/ tool for conversion.”
The next one is,“There are still some matrices and vectors in use. This might be an indicator of a possible waste of memory.”
Besides,there is also two info as followings:
" info: No source terms for process variable ‘phasefield’ found.
info: No source terms for process variable ‘displacement’ found."
I have no idea if these are related to the problem that i cannot get the output file and how can i get the output file.
Your kind help and suggestion are much appreciated.
