Dear All,
I have tried to prepare a small problem for THM modeling which will be basis for my large problem. OGS is not able to execute time steping and stops abruptly.
Thanks in advance for extending help.
Dr.A.K.Verma
disposal problem.zip (17.5 KB)
Dear Amit,
I think problems are in your GLI and MSH file (also you have not included any flow processes, you may go, LIQUID_FLOW or TWO_PHASE_FLOW). Please correct to input files according to the benchmarks.
https://svn.ufz.de/ogs/browser/trunk/benchmarks/THM
or
https://svn.ufz.de/ogs/browser/trunk/benchmarks/TH2M
Afterward, OGS able to execute time stepping and will not stops abruptly as currently.
Regards
Ashok
On Sat, Nov 3, 2012 at 6:54 PM, Amit Verma neurogeneticamit@gmail.com wrote:
Dear All,
Dr.A.K.Verma
Hi
I had a real quick look in case it was something obvious. There is something wrong with your .NUM file. If you run OGS using a command line, you get an error message relating to the NUM file. Also I note that there is no fluid flwo in your model, although you have fluid flow parameters defined in the mmp file. I suggest you try and find a benchmark which is as close as possible to your model, then alter the benchmark bit by bit until you get to your model.
Regards
Chris
Best regards
Chris McDermott
Dr. habil. C. I. McDermott M.Sc.
Senior Lecturer Hydrogeology and Coupled Process Modelling
School of Geosciences
Edinburgh University
Tel. ++44 (0) 131 6505931
Mob: ++44 (0) 7583431065
http://www.geos.ed.ac.uk/homes/cmcdermo
On 03/11/2012 17:54, Amit Verma wrote:
Dear All,
stops abruptly.
Dr.A.K.Verma
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
