Problem with installation of the OGS6 with DataExplorer
Dear, Users
When I download the released ogs6 with utils and execute “DataExplorer”, I have the following problem.
ERROR: In /datadrive/jenkins/workspace/0-EWDG5LJJ55/conan/.conan/data/VTK/7.1.0/bilke/stable/build/b59a343a9b498fdbbd94bc6e0e0b81bdfe2f1509/VTK-7.1.0/Rendering/OpenGL2/vtkShaderProgram.cxx, line 380
vtkShaderProgram (0x2b48bc0): 0:1(10): error: GLSL 1.50 is not supported. Supported versions are: 1.10, 1.20, 1.30, 1.00 ES, and 3.00 ES
I think that I have to install the OGS6 from source code at my linux(OS : Ubuntu 14.04) machine with GUI(‘DataExplorer’). Non-gui is well installed on my linux machine. However, when I turn on the cmake with as following :
cmake -L …/ogs \
-DOGS_BUILD_GUI:BOOL=ON \
-DShapelib_INCLUDE_DIR=$SHAPELIB_DIR/include \
-DShapelib_LIBRARY=$SHAPELIB_DIR/lib \
-DCMAKE_INSTALL_PREFIX=$HOME/externalpackage/ogs/install
The following ‘make’ error is :
Built target OGSFileConverterLib
In file included from /home/inwoo/externalpackage/ogs/ogs/Applications/DataExplorer/NetCdfDialog/NetCdfConfigureDialog.cpp:10:0:
/home/inwoo/externalpackage/ogs/ogs/Applications/DataExplorer/NetCdfDialog/NetCdfConfigureDialog.h:12:23: fatal error: netcdfcpp.h: No such file or directory
compilation terminated.
In file included from /home/inwoo/externalpackage/ogs/build/Applications/DataExplorer/NetCdfDialog/moc_NetCdfConfigureDialog.cpp:9:0,
             from /home/inwoo/externalpackage/ogs/build/Applications/DataExplorer/NetCdfDialog/NetCdfDialogLib_automoc.cpp:2:
/home/inwoo/externalpackage/ogs/build/Applications/DataExplorer/NetCdfDialog/…/…/…/…/ogs/Applications/DataExplorer/NetCdfDialog/NetCdfConfigureDialog.h:12:23: fatal error: netcdfcpp.h: No such file or directory
So I add the ‘netcdfcpp.h’ and ‘nvectors.h’ from ‘netcdf-cxx’ folder. But this does not work. I got the following problem.
Building CXX object MeshLib/CMakeFiles/MeshLib.dir/Node.cpp.o
cc1plus: warning: /home/inwoo/externalpackage/ogs/build/MeshLib/cotire/MeshLib_CXX_prefix.hxx.gch: created and used with different settings of -fpic
/home/inwoo/externalpackage/ogs/ogs/Applications/DataExplorer/NetCdfDialog/NetCdfConfigureDialog.cpp: In member function ‘void NetCdfConfigureDialog::createDataObject()’:
/home/inwoo/externalpackage/ogs/ogs/Applications/DataExplorer/NetCdfDialog/NetCdfConfigureDialog.cpp:339:39: error: no matching function for call to ‘get(double*&, long unsigned int*&)’
 _currentVar->get(data_array,length); //create Array of Values
I cannot solve this problem.
Inwoo
Dear Inwoo,
This sounds like your graphic driver does not support the required OpenGL functionality. Please check if you have a decent driver installed. But as you are using an old Linux distribution 14.04 this might be not that easy.
Also if you maybe have a really old graphic card it may not work at all.
Ubuntu 14.04) machine with GUI('DataExplorer'). Non-gui is well installed
cmake -L ../ogs \
See the developer guide for build instructions. You may want to use the Conan package manager for handling library dependencies:
directory
/../../../../ogs/Applications/DataExplorer/NetCdfDialog/
directory
So *I add the ‘netcdfcpp.h’ and ‘nvectors.h’ from ‘netcdf-cxx’ *folder. But
Inwoo
Dear Bilke,
I read your comments and install the ogs with conan usage. I works good.
When I used the “conan”, I got the problem with “sudo apt-get update”. Because my ‘update-manger’ has the corrupted ppa(personal package archive’, and it made a trouble. So I fixed it now, and installation of ogs with conan usage works good.
Thank you
Best regards
Inwoo
