Problems with HT process in 2D mesh (error in matrix)
The following is my HT prj for 2D mesh -
<?xml version='1.0' encoding='ISO-8859-1'?>
<OpenGeoSysProject>
    <meshes>
        <mesh>2Dmesh_initialfields.vtu</mesh>
        <mesh>leftHT.vtu</mesh>
        <mesh>2DboundaryHT.vtu</mesh>
    </meshes>
     <processes>
    <process>
      <name>th_decovalex</name>
      <type>HT</type>
      <coupling_scheme>staggered</coupling_scheme>
      <integration_order>4</integration_order>
      <process_variables>
        <temperature>T</temperature>
        <pressure>p</pressure>
      </process_variables>
      <specific_body_force>0 0 -9.81</specific_body_force>
      <secondary_variables>
        <secondary_variable internal_name="darcy_velocity" output_name="darcy_velocity" />
      </secondary_variables>
    </process>
  </processes>
    <media>
        <medium id="0">
            <phases>
                <phase>
                    <type>AqueousLiquid</type>
                    <properties>
                        <property>
                            <name>density</name>
                            <type>Constant</type>
                            <value>1000</value>
                        </property>
                        <property>
                            <name>viscosity</name>
                            <value>1.0e-3</value>
                        </property>
                        <property>
                            <name>specific_heat_capacity</name>
                            <value>4000</value>
                        </property>
                        <property>
                            <name>thermal_conductivity</name>
                            <value>18921600</value>
                        </property>
                    </properties>
                </phase>
                <phase>
                    <type>Solid</type>
                    <properties>
                        <property>
                            <name>storage</name>
                            <value>1e-10</value>
                        </property>
                        <property>
                            <value>2700</value>
                        </property>
                        <property>
                            <value>3.0 0 0 3.0</value>
                        </property>
                        <property>
                            <value>900</value>
                        </property>
                    </properties>
                </phase>
            </phases>
            <properties>
                <property>
                    <name>thermal_longitudinal_dispersivity</name>
                    <value>0.0</value>
                </property>
                <property>
                    <name>thermal_transversal_dispersivity</name>
                    <value>0.0</value>
                </property>
                <property>
                    <name>permeability</name>
                    <value>1e-13 0 0 0 1e-13 0 0 0 1e-13</value>
                </property>
                <property>
                    <name>porosity</name>
                    <value>0.30</value>
                </property>
                <property>
                    <type>EffectiveThermalConductivityPorosityMixing</type>
                </property>
            </properties>
        </medium>
        <medium id="1">
            <phases>
                <phase>
                    <properties>
                        <property>
                            <value>1000</value>
                        </property>
                        <property>
                        </property>
                        <property>
                            <value>4000</value>
                        </property>
                        <property>
                        </property>
                    </properties>
                </phase>
                <phase>
                    <type>Solid</type>
                    <properties>
                        <property>
                        </property>
                        <property>
                            <value>2160</value>
                        </property>
                        <property>
                            <value>5.5 0 0 5.5</value>
                        </property>
                        <property>
                            <value>900</value>
                        </property>
                    </properties>
                </phase>
            </phases>
            <properties>
                <property>
                    <value>0.0</value>
                </property>
                <property>
                    <value>0.0</value>
                </property>
                <property>
                    <value>5.5e-16 0 0 0 5.5e-16 0 0 0 5.5e-16 </value>
                </property>
                <property>
                    <value>0.12</value>
                </property>
                <property>
                </property>
            </properties>
        </medium>
    </media>
    <time_loop>
    <global_process_coupling>
      <max_iter>6</max_iter>
      <convergence_criteria>
        <convergence_criterion>
          <type>DeltaX</type>
          <norm_type>NORM2</norm_type>
          <reltol>1.e-14</reltol>
        </convergence_criterion>
          <type>DeltaX</type>
      </convergence_criteria>
    </global_process_coupling>
    <processes>
      <process ref="th_decovalex">
        <nonlinear_solver>basic_picard_T</nonlinear_solver>
          <type>DeltaX</type>
          <abstol>1.e-6</abstol>
        <time_discretization>
          <type>BackwardEuler</type>
        </time_discretization>
        <time_stepping>
          <type>FixedTimeStepping</type>
          <t_initial>0.0</t_initial>
          <t_end>1e3</t_end>
          <timesteps>
            <pair>
              <repeat>4</repeat>
              <delta_t>0.001</delta_t>
            </pair>
            <pair>
              <repeat>1</repeat>
              <delta_t>0.006</delta_t>
            </pair>
            <pair>
              <repeat>9</repeat>
              <delta_t>0.01</delta_t>
            </pair>
            <pair>
              <repeat>9</repeat>
              <delta_t>0.1</delta_t>
            </pair>
            <pair>
              <repeat>39</repeat>
              <delta_t>1.</delta_t>
            </pair>
            <pair>
              <repeat>2</repeat>
              <delta_t>2.0</delta_t>
            </pair>
            <pair>
              <repeat>1</repeat>
              <delta_t>16.0</delta_t>
            </pair>
            <pair>
              <repeat>1</repeat>
              <delta_t>30.0</delta_t>
            </pair>
            <pair>
              <repeat>1</repeat>
              <delta_t>40.0</delta_t>
            </pair>
            <pair>
              <repeat>10</repeat>
              <delta_t>86.0</delta_t>
            </pair>
            <pair>
              <repeat>90</repeat>
              <delta_t>100.0</delta_t>
            </pair>
            <pair>
              <repeat>100</repeat>
              <delta_t>900</delta_t>
            </pair>
            <pair>
              <repeat>90</repeat>
              <delta_t>1.e4</delta_t>
            </pair>
          </timesteps>
        </time_stepping>
      </process>
        <nonlinear_solver>basic_picard_H</nonlinear_solver>
          <type>DeltaX</type>
        <time_stepping>
          <t_end>1.e3</t_end>
          <timesteps>
            <pair>
              <repeat>4</repeat>
            </pair>
            <pair>
              <repeat>1</repeat>
            </pair>
            <pair>
              <repeat>9</repeat>
            </pair>
            <pair>
              <repeat>9</repeat>
            </pair>
            <pair>
              <repeat>39</repeat>
            </pair>
            <pair>
              <repeat>2</repeat>
            </pair>
            <pair>
              <repeat>1</repeat>
            </pair>
            <pair>
              <repeat>1</repeat>
            </pair>
            <pair>
              <repeat>1</repeat>
            </pair>
            <pair>
              <repeat>10</repeat>
            </pair>
            <pair>
              <repeat>90</repeat>
            </pair>
            <pair>
            </pair>
            <pair>
              <repeat>90</repeat>
            </pair>
          </timesteps>
        </time_stepping>
      </process>
    </processes>
    <output>
      <type>VTK</type>
      <prefix>th_decovalex</prefix>
      <suffix>ts{:timestep}_t_{:time}</suffix>
      <timesteps>
        <pair>
          <repeat>1</repeat>
          <each_steps>10</each_steps>
        </pair>
      </timesteps>
      <variables>
        <variable>T</variable>
        <variable>p</variable>
        <variable>darcy_velocity</variable>
      </variables>
    </output>
    </time_loop>
    <parameters>
        <parameter>
            <name>T0</name>
            <value>283</value>
        </parameter>
        <parameter>
            <name>heat_source</name>
            <type>MeshNode</type>
            <field_name>t_init</field_name>
        </parameter>
        <parameter>
            <name>p_in</name>
            <value>1.0e9</value>
        </parameter>
        <parameter>
            <name>ic</name>
            <field_name>p_init</field_name>
        </parameter>
    </parameters>
    <process_variables>
        <process_variable>
            <name>T</name>
            <components>1</components>
            <order>1</order>
            <initial_condition>heat_source</initial_condition>
            <boundary_conditions>
                <boundary_condition>
                    <mesh>2DboundaryHT</mesh>
                    <type>Dirichlet</type>
                    <parameter>T0</parameter>
                </boundary_condition>
            </boundary_conditions>
        </process_variable>
        <process_variable>
            <name>p</name>
            <order>1</order>
            <!-- Hydrostatic Initial Condition -->
            <initial_condition>ic</initial_condition>
            <!-- Boundary Conditions -->
                    <mesh>leftHT</mesh>
                    <type>Neumann</type>
                    <parameter>p_in</parameter>
        </process_variable>
    <nonlinear_solvers>
    <nonlinear_solver>
      <name>basic_picard_T</name>
      <type>Picard</type>
      <max_iter>10</max_iter>
      <linear_solver>linear_solver_T</linear_solver>
    </nonlinear_solver>
    <nonlinear_solver>
      <name>basic_picard_H</name>
      <type>Picard</type>
      <linear_solver>linear_solver_H</linear_solver>
    </nonlinear_solver>
  </nonlinear_solvers>
  <linear_solvers>
    <linear_solver>
      <name>linear_solver_T</name>
      <lis>-i cg -p jacobi -tol 1e-20 -maxiter 10000</lis>
      <eigen>
        <solver_type>BiCGSTAB</solver_type>
        <precon_type>DIAGONAL</precon_type>
        <error_tolerance>1e-20</error_tolerance>
      </eigen>
      <petsc>
        <prefix>T</prefix>
        <parameters>-T_ksp_type bcgs -T_pc_type bjacobi -T_ksp_rtol 1e-16 -T_ksp_max_it 10000</parameters>
      </petsc>
    </linear_solver>
    <linear_solver>
      <name>linear_solver_H</name>
      <eigen>
        <solver_type>CG</solver_type>
      </eigen>
      <petsc>
        <prefix>H</prefix>
        <parameters>-H_ksp_type cg -H_pc_type bjacobi -H_ksp_rtol 1e-16 -H_ksp_max_it 10000</parameters>
      </petsc>
    </linear_solver>
  </linear_solvers>
</OpenGeoSysProject>
My error persists when I convert it into 22 or 33
info: Global coupling iteration #0 started.
info: Solve process #0 (named as not given)
info: Iteration #1 started.
critical: C:/Users/gitlab/code/ogs/ogs/MaterialLib/MPL/Utils/FormEigenTensor.cpp:57 MaterialPropertyLib::FormEigenTensor<3>::operator ()()
warning: There are still 1 global matrices in use. This might be an indicator of a possible waste of memory.
warning: There are still 2 global vectors in use. This might be an indicator of a possible waste of memory.
error: Cannot convert a 2d tensor to 3x3 matrix
error: OGS terminated with error on 2025-09-13 22:45:32+0200.
Hi Ronia_a,
I guess the problem comes from the permeability. You’ve given 9 components, which OGS will interpret as a 3x3 tensor, which it rejects in a 2D setting.
In a 3D setting the 4 thermal conductivity components will likely cause problems:
                        <property>
                        </property>
Btw.: for isotropic properties a single component is sufficient.
I tried with single component for permeability and thermal conductivity,
but still the same error.
C:\THESIS DUMP\Series1\2D>“C:\THESIS DUMP\Series1\ogs-6.5.5.Windows-10.0.19045-python-3.13.2-utils\bin\ogs.exe” 2Drepo_prj_HT.prj
info: OGS started on 2025-09-15 11:17:14+0200 in serial mode.
info: This is OpenGeoSys-6 version 6.5.5.dirty. Log version: 2, Log level: info.
info: Eigen use 1 threads
info: Reading project file 2Drepo_prj_HT.prj.
info: readRasters …
info: readRasters done
info: ConstantParameter: T0
info: MeshNodeParameter: heat_source
info: ConstantParameter: p_in
info: MeshNodeParameter: ic
info: No source terms for process variable ‘T’ found.
info: No source terms for process variable ‘p’ found.
info: The equations of the coupled processes will be solved by the staggered scheme.
info: Initialize processes.
info: Time step #0 started. Time: 0. Step size: 0.
info: [time] Output of timestep 0 took 0.0029361 s.
info: Time step #0 took 0.0316513 s.
info: Solve processes.
info: Time step #1 started. Time: 0.001. Step size: 0.001.
error: OGS terminated with error on 2025-09-15 11:17:14+0200.
For the isotropic thermal_conductivity it is sufficient to give a scalar:
                        <property>
                            <value>5.5</value>
                        </property>
Alternatively for a 3d mesh, you can specify all components:
                        <property>
                            <value>5.5 0 0 0 5.5 0 0 0 5.5</value>
                        </property>
And same for the other thermal_conductivity with value 3.
– d
Ronia, you have two media. Did you correct all occurences of thermal conductivity and permeability?
Yes I have two media, I only kept the thermal conductivity for both the media 3*3 and rest is scalar .
Still the itartion starts and then says-
info: OGS started on 2025-09-16 14:57:54+0200 in serial mode.
info: readRasters …
info: [time] Output of timestep 0 took 0.0058556 s.
info: Time step #0 took 0.0161407 s.
critical: C:/Users/gitlab/code/ogs/ogs/MaterialLib/MPL/Utils/FormEigenTensor.cpp:67 MaterialPropertyLib::FormEigenTensor<2>::operator ()()
error: Cannot convert a 3d tensor to 2x2 matrix
error: OGS terminated with error on 2025-09-16 14:57:54+0200.
NOW THE PRJ LOOKS LIKE THIS BELOW-
<?xml version='1.0' encoding='ISO-8859-1'?> 2Dmesh_initialfields.vtu leftHT.vtu 2DboundaryHT.vtu
 <processes>
<process>
  <type>HT</type>
  <process_variables>
</process>
<media>
    <medium id="0">
        <phases>
            <phase>
                <properties>
                    <property>
                        <value>1000</value>
                    </property>
                    <property>
                    </property>
                    <property>
                        <value>4000</value>
                    </property>
                    <property>
                    </property>
                </properties>
            </phase>
            <phase>
                <type>Solid</type>
                <properties>
                    <property>
                    </property>
                    <property>
                        <value>2700</value>
                    </property>
                    <property>
                        <value>3.0 0 0 0 3.0 0 0 0 3.0</value>
                    </property>
                    <property>
                        <value>900</value>
                    </property>
                </properties>
            </phase>
        </phases>
        <properties>
            <property>
                <value>0.0</value>
            </property>
            <property>
                <value>0.0</value>
            </property>
            <property>
                <value>1e-13</value>
            </property>
            <property>
                <value>0.30</value>
            </property>
            <property>
            </property>
        </properties>
    </medium>
    <medium id="1">
        <phases>
            <phase>
                <properties>
                    <property>
                        <value>1000</value>
                    </property>
                    <property>
                    </property>
                    <property>
                        <value>4000</value>
                    </property>
                    <property>
                    </property>
                </properties>
            </phase>
            <phase>
                <type>Solid</type>
                <properties>
                    <property>
                    </property>
                    <property>
                        <value>2160</value>
                    </property>
                    <property>
                    </property>
                    <property>
                        <value>900</value>
                    </property>
                </properties>
            </phase>
        </phases>
        <properties>
            <property>
                <value>0.0</value>
            </property>
            <property>
                <value>0.0</value>
            </property>
            <property>
                <value>1e-21</value>
            </property>
            <property>
                <value>0.05</value>
            </property>
            <property>
            </property>
        </properties>
    </medium>
</media>
<time_loop>
      <type>DeltaX</type>
      <type>DeltaX</type>
<processes>
      <type>DeltaX</type>
    <time_stepping>
      <t_end>1e3</t_end>
      <timesteps>
        <pair>
          <repeat>4</repeat>
        </pair>
        <pair>
          <repeat>1</repeat>
        </pair>
        <pair>
          <repeat>9</repeat>
        </pair>
        <pair>
          <repeat>9</repeat>
        </pair>
        <pair>
          <repeat>39</repeat>
        </pair>
        <pair>
          <repeat>2</repeat>
        </pair>
        <pair>
          <repeat>1</repeat>
        </pair>
        <pair>
          <repeat>1</repeat>
        </pair>
        <pair>
          <repeat>1</repeat>
        </pair>
        <pair>
          <repeat>10</repeat>
        </pair>
        <pair>
          <repeat>90</repeat>
        </pair>
        <pair>
        </pair>
        <pair>
          <repeat>90</repeat>
        </pair>
      </timesteps>
    </time_stepping>
  </process>
      <type>DeltaX</type>
    <time_stepping>
      <t_end>1.e3</t_end>
      <timesteps>
        <pair>
          <repeat>4</repeat>
        </pair>
        <pair>
          <repeat>1</repeat>
        </pair>
        <pair>
          <repeat>9</repeat>
        </pair>
        <pair>
          <repeat>9</repeat>
        </pair>
        <pair>
          <repeat>39</repeat>
        </pair>
        <pair>
          <repeat>2</repeat>
        </pair>
        <pair>
          <repeat>1</repeat>
        </pair>
        <pair>
          <repeat>1</repeat>
        </pair>
        <pair>
          <repeat>1</repeat>
        </pair>
        <pair>
          <repeat>10</repeat>
        </pair>
        <pair>
          <repeat>90</repeat>
        </pair>
        <pair>
        </pair>
        <pair>
          <repeat>90</repeat>
        </pair>
      </timesteps>
    </time_stepping>
  </process>
</processes>
<output>
  <type>VTK</type>
  <timesteps>
    <pair>
      <repeat>1</repeat>
    </pair>
  </timesteps>
  <variables>
  </variables>
</output>
</time_loop>
<parameters>
    <parameter>
        <name>T0</name>
        <value>283</value>
    </parameter>
    <parameter>
    </parameter>
    <parameter>
        <name>p_in</name>
    </parameter>
    <parameter>
        <name>ic</name>
    </parameter>
</parameters>
<process_variables>
    <process_variable>
        <name>T</name>
        <order>1</order>
    </process_variable>
    <process_variable>
        <name>p</name>
        <order>1</order>
                <mesh>leftHT</mesh>
    </process_variable>
<nonlinear_solvers>
<nonlinear_solver>
  <type>Picard</type>
</nonlinear_solver>
<nonlinear_solver>
  <type>Picard</type>
</nonlinear_solver>
<linear_solvers>
<linear_solver>
linear_solver_T
T
</linear_solver>
<linear_solver>
linear_solver_H
H
</linear_solver>
</linear_solvers>
Now the conversion is from 3D to 2D. Do you try to have the same setup for 2D and 3D meshes?
I’d start with isotropic setup first (scalar quantities), and extend it to anisotropic later, when everything is running.
From the snippets it is difficult to judge, what is happening, please upload the complete setup with meshes (as simple as possible) here or some other place, so one could take a look without guessing.
– d
