Dear Users of OGS,
my name is Emiliano Sosa Massaro, nowadays I am trying to use the OGS # Phreeqc to do in coupling thermo-hydraulic simulation.
I am having problems when I want to modify the Engesgaard benchmark to simulate a hole in a 3D model and my simulation has ended delivering the following error message: Warning: Phreeqc does not run properly !!!
I would like to inject water through the whole open hole Interval, on this ground, I have created a polyline in .gli.
8 250 250 30 $ NAME wellbase; well
9 250 250 500 $ NAME welltop
#POLYLINE
$ NAME
WELL
$ EPSILON
1.0e-4
$ POINTS
8th
9
I hope someone could help me with an attached one can find the files I used. Files are stored in EOL Windows.
I will appreciate your help very much.
Thanks a lot in advance!
I get the following error:
C:\Users\p.raktikant.PC-STUDIOBESPR\Desktop\Q6_qv2 - Test> ogs Q5 > Q5_7.log
COutput::init(): could not initialize process pointer (process type INVALID_PROCESS) and appropriate mesh
COutput::init(): trying to fetch process pointer using msh_type_name …
failed
failed
failed
failed
Input file: phinp.dat
Output file: phinp.out
Database file: phreeqc.dat
║ * PHREEQC-3.4.0 * ║
║ A hydrogeochemical transport model ║
║ by ║
║ D.L. Parkhurst and C.A.J. Appelo ║
║ November 9, 2017 ║
Initializing…
ERROR: Concentration data error for c(4) in solution input.
ERROR: Concentration data error for ca in solution input.
ERROR: Concentration data error for mg in solution input.
ERROR: Concentration data error for cl in solution input.
ERROR: Calculations terminating due to input errors.
Stopping.
Q5.st (160 Bytes)
Q5.mfp (378 Bytes)
Q5.ic (1.75 KB)
Q5.gli (850 Bytes)
Q5.bc (1.48 KB)
Q5.num (2.79 KB)
Q5.pqc (1.88 KB)
Q5.pcs (884 Bytes)
