specifications of parameters for PARDISO direct solver
maybe somebody with a little experience in usage of the PARDISO solver can help me out with this:
Reading the code in Linear_EQS::Solver(CNumerics* num), it seems to me that all parameters set for the PARDISO solver are hardcoded in OGS (except for no. of threads), and specification of the linear solver parameters (error_tolerance max_iterations precond) in *.num should have no effect on the solution, as PARDISO is a direct solver. Nevertheless, I see (small) differences in the solution when specifying different values for the error_tolerance. Is there a point I'm completely missing about the operation of PARDISO?
Bests, Christof
Dr. Christof Beyer
Institute of Geosciences
Geohydromodelling
Ludewig-Meyn-Str. 10
24118 Kiel
Germany
phone: +49(0)431-8803172
fax: +49(0)431-8807606
mobile: +49(0)176-24297908
email: [email protected]
hi Christof,
i sometimes use pardiso but have never noticed the behavior. as you wrote, a solver tolerance in num files should have no influence on PARDISO. there could be invalid memory access somewhere in the code... are you sure you set 805 as a solver type? otherwise, iterative solvers from lis will be used.
regards,
nori
On 22 July 2015 16:43:37 CEST, Christof Beyer <[email protected]> wrote:
have
Bests, Christof
Sent from my Android device with K-9 Mail. Please excuse my brevity.
Hi Nori,
yes, I'm sure the PARDISO solver is chosen, it is stated in the screen output from OGS. I do not see the differences in all my models, though. The problem I am trying to solve is quite big (2.3 mio grid cells) and has a time variant source term (defined by a rfd curve), for which again I have problems reproducing the correct numbers.
Christof
Am 22.07.2015 um 17:06 schrieb Norihiro Watanabe:
hi Christof,
regards,
nori
have
Bests, Christof
Dr. Christof Beyer
Geohydromodelling
24118 Kiel
Germany
just information for you. I tested trunk version withe PARDISO for a simple groundwater flow with different tolerance numbers but didn't see the problem. maybe the problem is specific to your problem setting or your environment. For example, deactivation of sub-domains doesn't work well with PARDISO.
Nori
On 22/07/15 17:37, Christof Beyer wrote:
Hi Nori,
Christof
> hi Christof,
> regards,
> nori
>> Dear all,
>> have
>> Bests, Christof
Norihiro Watanabe, Dr.-Ing.
Telefon +49 341 235 1806
[email protected] / www.ufz.de
Administrativer Geschäftsführer: N.N.
