SSL certificate problems when accessing gitlab.opengeosys.org
We use SSL certificates from LetsEncrypt on all our websites. Recently their root certificate has expired and is replaced by a new one.
If you get errors, e.g. during git operations, like these:
fatal: unable to access 'https://gitlab.opengeosys.org/[some-repo].git/':
SSL certificate problem: certificate has expired
# OR
fatal: unable to access 'https://gitlab.opengeosys.org/ogs/ogs.git/':
server certificate verification failed. CAfile: none CRLfile: none
Then you have to apply outstanding updates to your operating system which should resolve the issues. See the following pages for more information:
If you cannot update your system you can temporarily disable SSL checks in git by setting the following environment variable:
export GIT_SSL_NO_VERIFY=true
