Structured Mesh in OpenGeosys
Hi All,
I want to generate structured mesh for Quad elements. I read following link
https://docs.opengeosys.org/docs/tools/meshing/structured-mesh-generation
Soil column width (x-direction)=0.1
Height (z-direction)=1.0
Along the z-direction, number of elements are 20.
I used following commands
bin/generateStructuredMesh -o quad_1x20.msh -e quad --lx .1 --lz 1.0 --nx 1 --nz 20
The error message is “error: Missing input: Length for dimension [1] is required but missing”. Any idea what is wrong here?
On the other hand, if I want to plot in x-y plane with same element number with following commands, it is working
bin/generateStructuredMesh -o quad_1x20.msh -e quad --lx .1 --ly 1.0 --nx 1 --ny 20
generateStructuredMesh is currently not supporting generation of a 2D mesh in x-z plane. After creating a mesh in x-y plane, you should run swapNodeCoordinateAxes tool to convert it to x-z plane.
nori
On 05/17/2017 06:27 AM, Mohammad Islam wrote:
Hi All,
Structured Mesh Generation
--nx 1 --nz 20
The error message is "error: Missing input: Length for dimension [1] is
required but missing". Any idea what is wrong here?
--nx 1 --ny 20
Groups "ogs-users" group.
an email to [email protected]
<mailto:[email protected]>.
Dear Nori,
Thank you for your reply.
I checked ogs6-utils-x32. But, did not find the swapNodeCoordinateAxes tool. However, in \ogs-master\Applications\Utils\MeshEdit, I found swapNodeCoordinateAxes.cpp. Is there any other source to find the swapNodeCoordinateAxes tool?
Thanks in advance.
On Tuesday, 16 May 2017 17:53:29 UTC-4, Norihiro Watanabe wrote:
nori
Hi All,
–nx 1 --nz 20
–nx 1 --ny 20
Groups “ogs-users” group.
mailto:[email protected].
how about the zip file linked from "Windows Data Explorer" in https://docs.opengeosys.org/download ?
n
On 05/17/2017 07:04 AM, Mohammad Islam wrote:
Dear Nori,
Thanks in advance.
    nori
    > Hi All,
    > I want to generate structured mesh for Quad elements. I read
    following link
    <https://docs.opengeosys.org/docs/tools/meshing/structured-mesh-generation&gt;
    > Soil column width (x-direction)=0.1
    > Height (z-direction)=1.0
    > Along the z-direction, number of elements are 20.
    > I used following commands
    > bin/generateStructuredMesh -o quad_1x20.msh -e quad --lx .1 --lz 1.0
    > --nx 1 --nz 20
    > The error message is "error: Missing input: Length for dimension
    [1] is
    > required but missing". Any idea what is wrong here?
    > On the other hand, if I want to plot in x-y plane with same element
    > number with following commands, it is working
    > bin/generateStructuredMesh -o quad_1x20.msh -e quad --lx .1 --ly 1.0
    > --nx 1 --ny 20
    > Regards,
    > Mohammad
    > You received this message because you are subscribed to the Google
    > Groups "ogs-users" group.
    > To unsubscribe from this group and stop receiving emails from it,
    send
    > an email to ogs-users+...@googlegroups.com <javascript:>
    > <mailto:ogs-users+...@googlegroups.com <javascript:>>.
    > For more options, visit https://groups.google.com/d/optout
    <https://groups.google.com/d/optout&gt;\.
Dear Nori,
Thank you. Yes, it is available there.
On Tuesday, 16 May 2017 18:10:39 UTC-4, Norihiro Watanabe wrote:
how about the zip file linked from “Windows Data Explorer” in
n
Dear Nori,
Thanks in advance.
nori
> Hi All,
following link
[https://docs.opengeosys.org/docs/tools/meshing/structured-mesh-generation](https://docs.opengeosys.org/docs/tools/meshing/structured-mesh-generation)
<[https://docs.opengeosys.org/docs/tools/meshing/structured-mesh-generation](https://docs.opengeosys.org/docs/tools/meshing/structured-mesh-generation)>
> --nx 1 --nz 20
[1] is
> --nx 1 --ny 20
> Regards,
> Mohammad
send
> an email to [email protected] <javascript:>
> <mailto:[email protected] <javascript:>>.
> For more options, visit [https://groups.google.com/d/optout](https://groups.google.com/d/optout)
<[https://groups.google.com/d/optout](https://groups.google.com/d/optout)>.
Dear Nori,
I generated structured mesh for Triangular element in XY plane (tri_2-40-xy.msh). Now using swapNodeCoordinateAxes
tool, I want to generate mesh in XZ plane. I used following command
bin/swapNodeCoordinateAxes -n XZY -o tri_2-40-xz.msh -i tri_2-40-xy.msh
The output file is tri_2-40-xz.msh. But, in the node coordinates, X, Z values are zero.
The soil column width and height are 0.1 m and 1.0 m.
Is there any other tricks to run swapNodeCoordinateAxes tools or is there anything missing in the command? For your kind consideration I attached input file (tri_2-40-xy.msh) & output file (tri_2-40-xz.msh)
Thanks in advance.
Regards
tri_2_40-xz.msh (2.21 KB)
tri_2-40-xy.msh (2.35 KB)
On Tuesday, 16 May 2017 21:21:53 UTC-4, Mohammad Islam wrote:
Dear Nori,
n
Dear Nori,
Thanks in advance.
nori
> Hi All,
following link
> --nx 1 --nz 20
[1] is
> --nx 1 --ny 20
> Regards,
> Mohammad
send
Hi Mohammad,
No there is no another trick. you did it correctly. I also tried and got the same wrong result. It seems there is a bug in the program. I'll check it later.
Meanwhile what you can do is manually swapping the columns using EXCEL or something similar, or using GINA which is available from
https://teambeam.bgr.de/my/drive#!folder=68
best,
nori
On 05/19/2017 03:59 AM, Mohammad Islam wrote:
Dear Nori,
Thanks in advance.
Regards
    Dear Nori,
        <https://docs.opengeosys.org/download&gt; ?
        n
         > Dear Nori,
         > Thank you for your reply.
         > I checked ogs6-utils-x32. But, did not find the
         > tool. However, in \ogs-master\Applications\Utils\MeshEdit, I
        found
         > swapNodeCoordinateAxes.cpp. Is there any other source to find
        the
         > swapNodeCoordinateAxes tool?
         > Thanks in advance.
         > Regards,
         > Mohammad
         > On Tuesday, 16 May 2017 17:53:29 UTC-4, Norihiro Watanabe wrote:
         > Hi,
         > generateStructuredMesh is currently not supporting
        generation of a 2D
         > mesh in x-z plane. After creating a mesh in x-y plane,
        you should run
         > swapNodeCoordinateAxes tool to convert it to x-z plane.
         > nori
         > On 05/17/2017 06:27 AM, Mohammad Islam wrote:
         > > Hi All,
         > > I want to generate structured mesh for Quad elements. I
        read
         > following link
         > <Structured Mesh Generation
        <https://docs.opengeosys.org/docs/tools/meshing/structured-mesh-generation&gt;&gt;
         > > Soil column width (x-direction)=0.1
         > > Height (z-direction)=1.0
         > > Along the z-direction, number of elements are 20.
         > > I used following commands
         > > bin/generateStructuredMesh -o quad_1x20.msh -e quad
        --lx .1 --lz 1.0
         > > --nx 1 --nz 20
         > > The error message is "error: Missing input: Length for
        dimension
         > [1] is
         > > required but missing". Any idea what is wrong here?
         > > On the other hand, if I want to plot in x-y plane with
        same element
         > > number with following commands, it is working
        --lx .1 --ly 1.0
         > > --nx 1 --ny 20
         > > Regards,
         > > Mohammad
         > > You received this message because you are subscribed to
        the Google
         > > Groups "ogs-users" group.
         > > To unsubscribe from this group and stop receiving
        emails from it,
         > send
         > > an email to ogs-users+...@googlegroups.com <javascript:>
         > > <mailto:ogs-users+...@googlegroups.com <javascript:>>.
         > > For more options, visit
         > <https://groups.google.com/d/optout
        <https://groups.google.com/d/optout&gt;&gt;\.
        Google
        it, send
         > <mailto:[email protected]>.
Dear Nori,
Thank you for your kind support.
On Thursday, 18 May 2017 18:00:26 UTC-4, Norihiro Watanabe wrote:
Hi Mohammad,
the same wrong result. It seems there is a bug in the program. I’ll
check it later.
best,
nori
Dear Nori,
values are zero.
Thanks in advance.
Regards
Dear Nori,
    [https://docs.opengeosys.org/download](https://docs.opengeosys.org/download)
    <[https://docs.opengeosys.org/download](https://docs.opengeosys.org/download)> ?
    n
     > Dear Nori,
    found
    the
     > Thanks in advance.
     > Regards,
     > Mohammad
     >     Hi,
    generation of a 2D
    you should run
     >     nori
     >     > Hi All,
    read
     >     following link
    <[https://docs.opengeosys.org/docs/tools/meshing/structured-mesh-generation](https://docs.opengeosys.org/docs/tools/meshing/structured-mesh-generation)>>
    --lx .1 --lz 1.0
     >     > --nx 1 --nz 20
    dimension
     >     [1] is
    same element
    --lx .1 --ly 1.0
     >     > --nx 1 --ny 20
     >     > Regards,
     >     > Mohammad
    the Google
    emails from it,
     >     send
    <[https://groups.google.com/d/optout](https://groups.google.com/d/optout)>>.
    Google
    it, send
the bug is fixed in master branch.
best,
nori
On 19.05.17 22:33, Mohammad Islam wrote:
Dear Nori,
    Hi Mohammad,
    got
    check it later.
    <https://teambeam.bgr.de/my/drive#!folder=68&gt;
    best,
    nori
    > Dear Nori,
    > I generated structured mesh for Triangular element in XY plane
    > (tri_2-40-xy.msh). Now using swapNodeCoordinateAxes
    > tool, I want to generate mesh in XZ plane. I used following command
    > bin/swapNodeCoordinateAxes -n XZY -o tri_2-40-xz.msh -i
    tri_2-40-xy.msh
    > The output file is tri_2-40-xz.msh. But, in the node coordinates,
    X, Z
    > values are zero.
    > The soil column width and height are 0.1 m and 1.0 m.
    > Is there any other tricks to run swapNodeCoordinateAxes tools or is
    > there anything missing in the command? For your kind consideration I
    > attached input file (tri_2-40-xy.msh) & output file (tri_2-40-xz.msh)
    > Regards,
    > Mohammad
    > Regards
    > On Tuesday, 16 May 2017 21:21:53 UTC-4, Mohammad Islam wrote:
    > Dear Nori,
    > Thank you. Yes, it is available there.
    > Regards,
    > Mohammad
    > On Tuesday, 16 May 2017 18:10:39 UTC-4, Norihiro Watanabe wrote:
    > how about the zip file linked from "Windows Data Explorer" in
    > https://docs.opengeosys.org/download
    > <https://docs.opengeosys.org/download
    <https://docs.opengeosys.org/download&gt;&gt; ?
    > n
    > On 05/17/2017 07:04 AM, Mohammad Islam wrote:
    > > Dear Nori,
    > > Thank you for your reply.
    > > I checked ogs6-utils-x32. But, did not find the
    > > tool. However, in
    > found
    > > swapNodeCoordinateAxes.cpp. Is there any other source
    to find
    > the
    > > swapNodeCoordinateAxes tool?
    > > Thanks in advance.
    > > Regards,
    > > Mohammad
    > > On Tuesday, 16 May 2017 17:53:29 UTC-4, Norihiro > Watanabe wrote:
    > > Hi,
    > > generateStructuredMesh is currently not supporting
    > generation of a 2D
    > > mesh in x-z plane. After creating a mesh in x-y plane,
    > you should run
    > > swapNodeCoordinateAxes tool to convert it to x-z
    plane.
    > > nori
    > > On 05/17/2017 06:27 AM, Mohammad Islam wrote:
    > > > Hi All,
    > > > I want to generate structured mesh for Quad
    elements. I
    > read
    > > following link
    <https://docs.opengeosys.org/docs/tools/meshing/structured-mesh-generation&gt;&gt;&gt;
    > > > Soil column width (x-direction)=0.1
    > > > Height (z-direction)=1.0
    > > > Along the z-direction, number of elements are 20.
    > > > I used following commands
    > > > bin/generateStructuredMesh -o quad_1x20.msh -e quad
    > --lx .1 --lz 1.0
    > > > --nx 1 --nz 20
    > > > The error message is "error: Missing input:
    Length for
    > dimension
    > > [1] is
    > > > required but missing". Any idea what is wrong here?
    > > > On the other hand, if I want to plot in x-y plane
    with
    > same element
    > > > number with following commands, it is working
    > --lx .1 --ly 1.0
    > > > --nx 1 --ny 20
    > > > Regards,
    > > > Mohammad
    > > > You received this message because you are
    subscribed to
    > the Google
    > > > Groups "ogs-users" group.
    > > > To unsubscribe from this group and stop receiving
    > emails from it,
    > > send
    > > > an email to ogs-users+...@googlegroups.com
    <javascript:>
    > > > <mailto:ogs-users+...@googlegroups.com
    <javascript:>>.
    > > > For more options, visit
    > https://groups.google.com/d/optout
    > > <https://groups.google.com/d/optout
    <https://groups.google.com/d/optout&gt;&gt;&gt;\.
    the
    > Google
    emails from
    > it, send
    > > <mailto:[email protected]>.
    send
渡邉 教弘(工博 Dr.-Ing.)
国立研究開発法人 産業技術総合研究所
再生可能エネルギー研究所(FREA)
再生可能エネルギー研究センター
地熱チーム 研究員
〒963-0298 福島県郡山市待池台二丁目2番9
TEL: 029-861-4463 (内222-44463)
FAX: 024-963-0828
E-MAIL: [email protected]
URL: 産総研:福島再生可能エネルギー研究所
Dear Nori,
Thank you for your update. I will check it soon.
On Monday, 22 May 2017 07:55:19 UTC-4, Norihiro Watanabe wrote:
https://github.com/ufz/ogs/pull/1815
best,
nori
Dear Nori,
Hi Mohammad,
got
check it later.
[https://teambeam.bgr.de/my/drive#!folder=68](https://teambeam.bgr.de/my/drive#!folder=68)
<[https://teambeam.bgr.de/my/drive#!folder=68](https://teambeam.bgr.de/my/drive#!folder=68)>
best,
nori
> Dear Nori,
tri_2-40-xy.msh
X, Z
> values are zero.
> Thanks in advance.
> Regards,
> Mohammad
> Regards
>     Dear Nori,
>     Regards,
>     Mohammad
<[https://docs.opengeosys.org/download](https://docs.opengeosys.org/download)>> ?
>         n
>          > Dear Nori,
>          > tool. However, in
>         found
to find
>         the
>          > Thanks in advance.
>          > Regards,
>          > Mohammad
>          > On Tuesday, 16 May 2017 17:53:29 UTC-4, Norihiro > >     Watanabe wrote:
>          >     Hi,
>         generation of a 2D
>         you should run
plane.
>          >     nori
>          >     > Hi All,
elements. I
>         read
>          >     following link
<[https://docs.opengeosys.org/docs/tools/meshing/structured-mesh-generation](https://docs.opengeosys.org/docs/tools/meshing/structured-mesh-generation)>>>
>         --lx .1 --lz 1.0
>          >     > --nx 1 --nz 20
Length for
>         dimension
>          >     [1] is
with
>         same element
>         --lx .1 --ly 1.0
>          >     > --nx 1 --ny 20
>          >     > Regards,
>          >     > Mohammad
subscribed to
>         the Google
>         emails from it,
>          >     send
<javascript:>
<javascript:>>.
<[https://groups.google.com/d/optout](https://groups.google.com/d/optout)>>>.
the
>         Google
emails from
>         it, send
[https://groups.google.com/d/optout](https://groups.google.com/d/optout) <[https://groups.google.com/d/optout](https://groups.google.com/d/optout)>
send
渡邉 教弘(工博 Dr.-Ing.)
国立研究開発法人 産業技術総合研究所
再生可能エネルギー研究所(FREA)
再生可能エネルギー研究センター
地熱チーム 研究員
FAX: 024-963-0828
E-MAIL: norihiro…@aist.go.jp
URL: http://www.aist.go.jp/fukushima/
