T in °C or K
I came across an inconsistency in units in OGS which is worrying me.
We ran a coupled H2T model (PP model for multiphase flow), where T is defined in [°C]. We found that when the density function is called from CalCoefMass2() for example, T is converted to [K] by
if(diffusion)
  TG = interpolate(NodalValC1) + T_KILVIN_ZERO;
Then Density(variables) is called. In our model, rho=f(P,T) (model 6) and the reference T_0 = 21 °C is mfp-input value in [°C], which is intuitive, as her whole model runs with BCs and IC T in [°C].
In this case
delta_T = variables[1] in [K] - T_0 in [°C]
which gives quite a large delta_T (~274°) and thus a very large density change (-110 kg/m³).
So in order to correctly use the PP model and T-dependent density,
it seems to me we have to define IC, BC etc. in [°C], but the mfp-density parameter for rho(T) in [K]. If this is true, I think we should generally think about the way we handle T-units in OGS, as user errors are very likely with the current implementation.
I also found that for other processes the + T_KILVIN_ZERO temperature transformation is applied:
- CalCoefMass()
   - Richards
- CalCoefLaplace()
   - Richards (if(MediaProp->permeability_stress_mode > 1))
   - Liquidflow (if(MediaProp->permeability_stress_mode > 1))
   - Airflow
- CalCoefLaplace2()
- CalCoefAdvection()
   - Heat (if(FluidProp->density_model == 14)
- CalcAdvection
   -(if(multiphase))
and several CalCoef_RHS... functions
These seem to be mostly special cases (but I'm not completely sure) but some warning messages should probably be be added as long as there is no standard internal T unit.
What do you think?
Have a nice evening,
Christof
Dr. Christof Beyer
Institute of Geosciences
Geohydromodelling
Ludewig-Meyn-Str. 10
24118 Kiel
Germany
phone: +49(0)431-8803172
fax: +49(0)431-8807606
mobile: +49(0)176-24297908
email: [email protected]
Hi Christof,
as you might know I had a similar issue with the Density() functions and T_KILVIN_ZERO while working on coupled H2T models with ECLIPSE. My temporary fix was to implement a flag to switch the addition of T_KILVIN_ZERO on and off (should be already in the Kiel branch I think...).
Anyway, in my opion SI-units should be used throughout the code for all processes. Mixing °C and K truly is a bad idea, especially if there is no proper manual the user can refer to (easily that is). For those who really need °C maybe we can implement a keyword that changes all input/output variables related to the heat transport from K to °C. This way it would be the users responsibility to supply all necessary input values in consistent units.
So bottom line: To keep some consistency within the code I woud vote for SI-units throughout.
Good night & take care,
Tilmann
Am 07.07.15 um 18:12 schrieb Christof Beyer:
if(diffusion)
In this case
- CalCoefMass()
  - Richards
- CalCoefLaplace()
  - Airflow
- CalCoefLaplace2()
- CalcAdvection
  -(if(multiphase))
What do you think?
Christof
Wolf Tilmann Pfeiffer
Geohydromodelling
Christian-Albrechts-University of Kiel
Ludewig-Meyn-Strasse 10, 24118 Kiel, Germany
phone: 0049 (0)431 880-4805
+1 to Tilmann's suggestion!
best,
nori
On 07/07/15 18:12, Christof Beyer wrote:
if(diffusion)
In this case
- CalCoefMass()
   - Richards
- CalCoefLaplace()
   - Airflow
- CalCoefLaplace2()
- CalcAdvection
   -(if(multiphase))
What do you think?
Christof
Norihiro Watanabe, Dr.-Ing.
Telefon +49 341 235 1806
[email protected] / www.ufz.de
Administrativer Geschäftsführer: N.N.
+2
Greetings, georg
Am 07.07.2015 um 22:00 schrieb Norihiro Watanabe:
best,
nori
if(diffusion)
In this case
- CalCoefMass()
   - Richards
- CalCoefLaplace()
   - Airflow
- CalCoefLaplace2()
- CalcAdvection
   -(if(multiphase))
What do you think?
Christof
+3
Dr. rer. nat. Marc Walther
Hydrologist
Permoserstraße 15, 04318 Leipzig, Germany
Phone +49 341 235 10 54
Fax +49 341 235 19 39
Mobile +49 178 334 18 19
Email [email protected]
Web http://www.ufz.de
Personal Seite nicht verfügbar / page not available
Research http://www.researchgate.net/profile/Marc_Walther
Registered Office: Leipzig
Registration Office: Amtsgericht Leipzig
Trade Register Nr. B 4703
Chairman of the Supervisory Board: MinR Wilfried Kraus
Scientific Director: Prof. Dr. Georg Teutsch
Administrative Director: Dr. Heike Graßmann
Sent from mobile device, please excuse spelling mistakes.
Am 7. Juli 2015 22:01:55 schrieb Georg Kosakowski <[email protected]>:
+2
Greetings, georg
> best,
> nori
>> Dear all,
>> if(diffusion)
>> In this case
>> - CalCoefMass()
>> - Richards
>> - CalCoefLaplace()
>> - Airflow
>> - CalCoefLaplace2()
>> - CalcAdvection
>> -(if(multiphase))
>> What do you think?
>> Christof
You received this message because you are subscribed to the Google Groups "ogs-devs" group.
It causes confusion to use °C as temperature unit. I agree with Wolf to only use K as temperature unit. I will check it in next week.
On 07/07/2015 06:12 PM, Christof Beyer wrote:
if(diffusion)
In this case
- CalCoefMass()
  - Richards
- CalCoefLaplace()
  - Airflow
- CalCoefLaplace2()
- CalcAdvection
  -(if(multiphase))
What do you think?
Christof
Dear Christof,
As a temporary solution for your calculation, you can change your input data of T0 as 294 (273+21) for density model 6 or for any other temperature data for fluids material properties, and keep the temperature unit for IC and Direchlet BC in °C. By this way, you get temperature solution in °C due to
rho C d(T+273)/dt = rho C dT/dt
grad(K grad(T+273)) = grad(K grad T)
Wenqing
if(diffusion)
In this case
- CalCoefMass()
  - Richards
- CalCoefLaplace()
  - Airflow
- CalCoefLaplace2()
- CalcAdvection
  -(if(multiphase))
What do you think?
Christof
Dear Christof,
Wenqing
if(diffusion)
In this case
- CalCoefMass()
  - Richards
- CalCoefLaplace()
  - Airflow
- CalCoefLaplace2()
- CalcAdvection
  -(if(multiphase))
What do you think?
Christof
Phone: +41-56-3104743 * Email: [email protected]
homepage: PD Dr. Georg Kosakowski | Laboratory for Waste Management | PSI
sorry for the empty email. Please use/implement the correct conversion
from C to K: 0°C = 273.15K
Greetings, Georg
Dear Christof,
Wenqing
if(diffusion)
In this case
- CalCoefMass()
  - Richards
- CalCoefLaplace()
  - Airflow
- CalCoefLaplace2()
- CalcAdvection
  -(if(multiphase))
What do you think?
Christof
