Hello, I’m starting to use OGS5 and I’m testing some benchmarks \FLUID_PROPERTIES\HT_EOS-B, which works with several substances.
My question is: Is there a summary-table of the state equations used by opengeosys for the density and viscosity?
Saludos Cordiales
Norberto C. Vera Guzmán
Instituto de Geofísica, UNAM
Dear Norberto C. Vera Guzmán,
Please explain little more, what do you mean by “Is there a summary-table of the state equations used by opengeosys for the density and viscosity?”
Are you looking, fluid’s density and viscosity related algorithms and their associated information in OGS5? Any specific fluid?
Are you looking for Equation of State only, e.g., Peng-Robinso, HEOS etc?
Are you looking fluid flow governing equation and their simplified form?
Saludos Cordiales
Thank you for answering my question Mohammad
The benchmark that I mention has a directory of substances, … \ FLUID_PROPERTIES \ HT_EOS-B \ Substances
containing files (* .mfp) for several substances (CH4, CO2, H2O and N2). Within the files (* .mfp) some parameters are defined, specifically within the H2O-HE.mfp, H2O-PR.mfp y H2O-RK.mfp files we have:
$ DENSITY
13
$ VISCOSITY
9
$ DENSITY
12
$ VISCOSITY
9
$DENSITY
11
$VISCOSITY
9
my question is:
Is there a summary-table that tells me what equation state I’m using to calculate density or viscosity when I use option (13,9), (12,9) or (11,9) in the (*.mfp) files?
Thanks for your help
You will get all of your *.mfp file related answers in the following file
rf_mfp_new.cpp
As for example:
if ((density_model == 10) // NB 4.8.01 read density from a rho-P-T table
>> (density_model == 11) // NB 4.9.05 Peng-Robinson Equation of State
>> (density_model == 12) // NB 4.9.05 Redlich-Kwong Equation of State
>> (density_model == 13)) // NB JUN 09 Fundamental equation
In addition, please check the following reference
[1] O. Kolditz, U.-J. Gorke, H. Shao, W. Wang, Thermo-Hydro-Mechanical-Chemical Processes in Fractured Porous Media: Benchmarks and Examples, Springer, Heidelberg, 2012. Page:32-42
To play with equation of state, you may also try NIST (https://www.nist.gov/), Coolprop (http://www.coolprop.org/) or REFPROP (https://www.nist.gov/srd/refprop). Even though in the above mentioned reference, for viscosity PR and RK were used, but some points I am not convinced with my hand calculation. For safe side, I would prefer to use HEOS/Fundamental one. If you really inetrested to dig its bottom, I will recommend you to read first some basic papers and text books.
Good Luck.
Cheers
$ DENSITY
13
$ VISCOSITY
9
$ DENSITY
12
$ VISCOSITY
9
$DENSITY
11
$VISCOSITY
9
my question is:
Saludos Cordiales
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected].
You are very kind Mohammad.
Thanks for your help and your time.
Best regards
