TH2M Test case
Hi All,
I am trying to run a TH2M case. But, coupling is not working. I checked TH2M example problem, and used similar *.num file. After Process 1: HEAT_TRANSPORT
"Inner coupling loop 1/3 complete
Max coupling error (relative error tolerance):0"
After Process 2: DEFORMATION
Starting loading step 1/1. Load factor :1
Assembling equation system…
Then terminated. Any idea? Most likely, problem originated from the *.num file.
Any cooperation will be appreciable. In addition, is there any way to take complete error message and log in a text file?
*.bc
#BOUNDARY_CONDITION
MULTI_PHASE_FLOW
$PRIMARY_VARIABLE
PRESSURE1
$GEO_TYPE
POLYLINE BOTTOM
$DIS_TYPE
CONSTANT 0
#BOUNDARY_CONDITION
MULTI_PHASE_FLOW
$PRIMARY_VARIABLE
PRESSURE2
$GEO_TYPE
POLYLINE TOP
$DIS_TYPE
CONSTANT 0
#BOUNDARY_CONDITION
MULTI_PHASE_FLOW
$PRIMARY_VARIABLE
PRESSURE2
$GEO_TYPE
POLYLINE BOTTOM
$DIS_TYPE
CONSTANT 0
#BOUNDARY_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
DISPLACEMENT_Y1
$GEO_TYPE
POLYLINE BOTTOM
$DIS_TYPE
CONSTANT 0
#BOUNDARY_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
DISPLACEMENT_X1
$GEO_TYPE
POLYLINE left
$DIS_TYPE
CONSTANT 0
#BOUNDARY_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
DISPLACEMENT_X1
$GEO_TYPE
POLYLINE right
$DIS_TYPE
CONSTANT 0
#BOUNDARY_CONDITION
HEAT_TRANSPORT
$PRIMARY_VARIABLE
TEMPERATURE1
$GEO_TYPE
POLYLINE TOP_C
$DIS_TYPE
CONSTANT 70
*.ic
#INITIAL_CONDITION
MULTI_PHASE_FLOW
$PRIMARY_VARIABLE
PRESSURE1
$GEO_TYPE
DOMAIN
$DIS_TYPE
CONSTANT 0
#INITIAL_CONDITION
MULTI_PHASE_FLOW
$PRIMARY_VARIABLE
PRESSURE2
$GEO_TYPE
DOMAIN
$DIS_TYPE
CONSTANT 0
#INITIAL_CONDITION
HEAT_TRANSPORT
$PRIMARY_VARIABLE
TEMPERATURE1
$GEO_TYPE
DOMAIN
$DIS_TYPE
CONSTANT 30.0
*.mfp
#FLUID_PROPERTIES
$FLUID_TYPE
LIQUID
PRESSURE1
$DENSITY
1 1.000000e+003
$VISCOSITY
1 1.000000e-003
$SPECIFIC_HEAT_CAPACITY
1 4.280000e+003
$HEAT_CONDUCTIVITY
1 6.000000e-001
#FLUID_PROPERTIES
$FLUID_TYPE
GAS
PRESSURE2
$DENSITY
7
$VISCOSITY
1 1.8e-005
1 1.01e+3
$HEAT_CONDUCTIVITY
1 0.026
$PHASE_DIFFUSION
1 2.13e-6
*.mmp
#MEDIUM_PROPERTIES
$GEOMETRY_DIMENSION
2
$GEOMETRY_AREA
1.000000e+000
$POROSITY
1 2.975000e-001
$TORTUOSITY
1 0.8
$DIFFUSION
273
$PERMEABILITY_TENSOR
ISOTROPIC 4.500000e-013
$PERMEABILITY_SATURATION
0 2
0 2
$CAPILLARY_PRESSURE
0 1
*.msp
#SOLID_PROPERTIES
$DENSITY
1 -2000
$THERMAL
EXPANSION: 1.0e-5
CAPACITY:
1 1.091000e+003
CONDUCTIVITY:
1 0.4200000e+000
$ELASTICITY
POISSION 0.4
YOUNGS_MODULUS:
1 1.300000e+006
$BIOT_CONSTANT
1
*.num
GeoSys-NUM: Numerical Parameter ----------------------------------------
$OVERALL_COUPLING
;min_iter – max_iter
1 1
#NUMERICS
MULTI_PHASE_FLOW
$LINEAR_SOLVER
; method error_tolerance max_iterations theta precond storage
2 2 1.e-10 2000 1.0 100 4
$ELE_MASS_LUMPING
0
$ELE_GAUSS_POINTS
2
$NON_LINEAR_SOLVER
; method error_tolerance max_iterations relaxation
PICARD 1.0e-4 30 0.0
$COUPLING_CONTROL
;error method – tolerances
LMAX 1.e-3 1.e-3
$COUPLED_PROCESS
;process or variable – min_iter – max_iter
HEAT_TRANSPORT 1 3
#NUMERICS
HEAT_TRANSPORT
$LINEAR_SOLVER
2 1 1.e-012 1000 0.5 100 4
$NON_LINEAR_SOLVER
PICARD 1.0e-6 100 0.0
$COUPLING_CONTROL
LMAX 1.e-6
#NUMERICS
DEFORMATION
$NON_LINEAR_SOLVER
NEWTON 1e-2 1e-10 100 0.0
$LINEAR_SOLVER
2 0 1.e-011 2000 1.0 100 4
$COUPLING_CONTROL
LMAX 1.e-3
you can do it as
ogs &> log.txt
On 06/22/2017 03:31 AM, Mohammad Islam wrote:
Hi All,
Assembling equation system...
*.bc
#BOUNDARY_CONDITION
MULTI_PHASE_FLOW
$PRIMARY_VARIABLE
PRESSURE1
$GEO_TYPE
POLYLINE BOTTOM
$DIS_TYPE
CONSTANT 0
#BOUNDARY_CONDITION
MULTI_PHASE_FLOW
$PRIMARY_VARIABLE
PRESSURE2
$GEO_TYPE
POLYLINE TOP
$DIS_TYPE
CONSTANT 0
#BOUNDARY_CONDITION
MULTI_PHASE_FLOW
$PRIMARY_VARIABLE
PRESSURE2
$GEO_TYPE
POLYLINE BOTTOM
$DIS_TYPE
CONSTANT 0
#BOUNDARY_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
DISPLACEMENT_Y1
$GEO_TYPE
POLYLINE BOTTOM
$DIS_TYPE
CONSTANT 0
#BOUNDARY_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
DISPLACEMENT_X1
$GEO_TYPE
POLYLINE left
$DIS_TYPE
CONSTANT 0
#BOUNDARY_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
DISPLACEMENT_X1
$GEO_TYPE
POLYLINE right
$DIS_TYPE
CONSTANT 0
#BOUNDARY_CONDITION
HEAT_TRANSPORT
$PRIMARY_VARIABLE
TEMPERATURE1
$GEO_TYPE
POLYLINE TOP_C
$DIS_TYPE
CONSTANT 70
*.ic
#INITIAL_CONDITION
MULTI_PHASE_FLOW
$PRIMARY_VARIABLE
PRESSURE1
$GEO_TYPE
DOMAIN
$DIS_TYPE
CONSTANT 0
#INITIAL_CONDITION
MULTI_PHASE_FLOW
$PRIMARY_VARIABLE
PRESSURE2
$GEO_TYPE
DOMAIN
$DIS_TYPE
CONSTANT 0
#INITIAL_CONDITION
HEAT_TRANSPORT
$PRIMARY_VARIABLE
TEMPERATURE1
$GEO_TYPE
DOMAIN
$DIS_TYPE
CONSTANT 30.0
*.mfp
#FLUID_PROPERTIES
$FLUID_TYPE
LIQUID
PRESSURE1
$DENSITY
1 1.000000e+003
$VISCOSITY
1 1.000000e-003
1 4.280000e+003
$HEAT_CONDUCTIVITY
1 6.000000e-001
#FLUID_PROPERTIES
$FLUID_TYPE
GAS
PRESSURE2
$DENSITY
7
$VISCOSITY
1 1.8e-005
1 1.01e+3
$HEAT_CONDUCTIVITY
1 0.026
$PHASE_DIFFUSION
1 2.13e-6
*.mmp
#MEDIUM_PROPERTIES
$GEOMETRY_DIMENSION
2
$GEOMETRY_AREA
1.000000e+000
$POROSITY
1 2.975000e-001
$TORTUOSITY
1 0.8
$DIFFUSION
273
0 2
0 2
$CAPILLARY_PRESSURE
0 1
*.msp
#SOLID_PROPERTIES
$DENSITY
1 -2000
$THERMAL
EXPANSION: 1.0e-5
CAPACITY:
1 1.091000e+003
CONDUCTIVITY:
1 0.4200000e+000
$ELASTICITY
POISSION 0.4
YOUNGS_MODULUS:
1 1.300000e+006
$BIOT_CONSTANT
1
*.num
$OVERALL_COUPLING
;min_iter -- max_iter
1 1
#NUMERICS
MULTI_PHASE_FLOW
$LINEAR_SOLVER
$ELE_MASS_LUMPING
0
$ELE_GAUSS_POINTS
2
$NON_LINEAR_SOLVER
$COUPLING_CONTROL
;error method -- tolerances
LMAX 1.e-3 1.e-3
$COUPLED_PROCESS
;process or variable -- min_iter -- max_iter
HEAT_TRANSPORT 1 3
#NUMERICS
HEAT_TRANSPORT
$LINEAR_SOLVER
$NON_LINEAR_SOLVER
$COUPLING_CONTROL
LMAX 1.e-6
#NUMERICS
DEFORMATION
$NON_LINEAR_SOLVER
$LINEAR_SOLVER
$COUPLING_CONTROL
LMAX 1.e-3
Dear Nori,
Thank you.
Hi All,
Still I am having trouble with TH2M coupling. H2M case individually working fine, but when I added Thermal part, OGS stopped working with error messages as follows
SolidProperties: HeatConductivity Tensor (): conductivity mode is not supported
Error: in CMediumProperties:: Heat Capacity: no valid material model
OGS stopped
Any idea?
For convenience I attached H2M and TH2M case files. Source of the file: Benchmark Problem>> TH2M/H2M_TEM. In addition, it is to note that under JFNK folder, example problem is not running due to JFNK solver (it is no longer supported). Furthermore, under Newton folder, process is DEFORMATION_H2. Does it represent TH2M case? I attempted to modify for TH2M case, but it is not working. Finally, in same folder for Benchmark problem, th2m_quad.** , after initial state there is no evolution with respect to time. I checked it and found capillary pressure, gas pressure, saturation are same, which is not rational. Any co-operation will be appreciable.
In addition, I am also reading attached paper by Kolditz et al. (2012) " A systematic benchmarking approach for geologic CO2 injection and storage", Env. Earth Sc. 67: 613-632 . In Table 1: Non-isothermal two-phase flow consolidation TH2M case presented. I am wondering is there any way to get the benchmark example?
Thanks in advance.
w_exp.bc (1.06 KB)
w_exp.gli (840 Bytes)
w_exp.ic (709 Bytes)
w_exp.mfp (285 Bytes)
w_exp.mmp (375 Bytes)
w_exp.msh (1.94 KB)
w_exp.num (764 Bytes)
w_exp.out (2.63 KB)
w_exp.pcs (410 Bytes)
w_exp.rfd (5.87 KB)
w_exp.st (402 Bytes)
w_exp.tim (264 Bytes)
th2m-w_exp.bc (1.2 KB)
th2m-w_exp.gli (996 Bytes)
th2m-w_exp.ic (842 Bytes)
th2m-w_exp.mfp (481 Bytes)
th2m-w_exp.mmp (417 Bytes)
th2m-w_exp.msh (1.96 KB)
th2m-w_exp.num (1.5 KB)
th2m-w_exp.out (3.75 KB)
th2m-w_exp.pcs (452 Bytes)
w_exp.rfd (5.87 KB)
th2m-w_exp.tim (631 Bytes)
10.1007_s12665-012-1656-5.pdf (1.53 MB)
th2m-w_exp.msp
GeoSys-MAT-SP: Solid Properties ------------------------------------
#SOLID_PROPERTIES
$DENSITY
1 2010.0
$THERMAL
EXPANSION 1.0e-5
CAPACITY:
3
CONDUCTIVITY:
3
$ELASTICITY
POISSION 0.35
YOUNGS_MODULUS:
1 3.17e+8
$SWELLING_PRESSURE_TYPE
2 4.76e6
Hi, can you also send us MSP files? I can't find them in the attachments.
n
On 06/28/2017 06:03 AM, Mohammad Islam wrote:
Hi All,
  OGS stopped
Any idea?
Thanks in advance.
th2m-w_exp.msp
#SOLID_PROPERTIES
$DENSITY
1 2010.0
$THERMAL
EXPANSION 1.0e-5
CAPACITY:
3
CONDUCTIVITY:
3
$ELASTICITY
POISSION 0.35
YOUNGS_MODULUS:
1 3.17e+8
2 4.76e6
sorry, the MSP part was included in the message body. In the file, you need to add a function type before giving the value like
CAPACITY:
1 800.0
CONDUCTIVITY:
1 3.0
The first number 1 means you use a constant value for the solid phase conductivity. Depending on a parameter type, you may be able to choose other function type such as f(t) or f(T).
see for example, https://svn.ufz.de/ogs/browser/trunk/benchmarks/TH2M/th2m_quad.msp
nori
n
Hi All,
  OGS stopped
Any idea?
Thanks in advance.
th2m-w_exp.msp
#SOLID_PROPERTIES
$DENSITY
1 2010.0
$THERMAL
EXPANSION 1.0e-5
CAPACITY:
3
CONDUCTIVITY:
3
$ELASTICITY
POISSION 0.35
YOUNGS_MODULUS:
1 3.17e+8
2 4.76e6
Dear Nori,
Thank you. Error message resolved. But, still having problem.
I prepared two sets of test: HM (Richards Flow) & H2M (Multiphase flow), then added Thermal part. HM, H2M, THM cases are running, but in TH2M case after initial state in results only .#IND and #QNAN (not a number?). On the other hand, in THM case results are identical to the HM case. I attached comparison.xls file (THM with & without heat injection and HM case).
HM.MSP
#SOLID_PROPERTIES
$DENSITY
1 -2000
$ELASTICITY
POISSION 0.4
YOUNGS_MODULUS:
1 1.300000e+006
THM.MSP
#SOLID_PROPERTIES
$DENSITY
1 -2000
$THERMAL
EXPANSION: 1.0e-5
CAPACITY:
1 1.091000e+003
CONDUCTIVITY:
1 0.4200000e+000
$ELASTICITY
POISSION 0.4
YOUNGS_MODULUS:
1 1.300000e+006
Thanks in advance.
comparison.xlsx (42.2 KB)
HM-Un-Lia-Q.bc (896 Bytes)
HM-Un-Lia-Q.gli (1.05 KB)
HM-Un-Lia-Q.ic (258 Bytes)
HM-Un-Lia-Q.mfp (405 Bytes)
HM-Un-Lia-Q.mmp (538 Bytes)
HM-Un-Lia-Q.msh (2.33 KB)
HM-Un-Lia-Q.num (1.59 KB)
HM-Un-Lia-Q.out (840 Bytes)
HM-Un-Lia-Q.pcs (171 Bytes)
HM-Un-Lia-Q.rfd (1.19 KB)
HM-Un-Lia-Q.st (1 KB)
HM-Un-Lia-Q.tim (763 Bytes)
THM-Un-Lia-Q.bc (1.06 KB)
THM-Un-Lia-Q.ic (435 Bytes)
THM-Un-Lia-Q.mfp (489 Bytes)
THM-Un-Lia-Q.mmp (580 Bytes)
THM-Un-Lia-Q.num (1.91 KB)
THM-Un-Lia-Q.out (885 Bytes)
THM-Un-Lia-Q.pcs (236 Bytes)
THM-Un-Lia-Q.st (1 KB)
THM-Un-Lia-Q.tim (1.03 KB)
