Hello all,
I fixed a few issues concerning the coupling between OGS and Eclipse as well as adding a function to save/copy the .data files of Eclipse for additional benchmarking.
Furthermore, I reworked some of the benchmarks in ECLIPSE_DUMUX so that they are running & working again with the current OGS version.
Testing my version in the branch reveals that quite a few benchmarks are not working:
The following tests FAILED:
NB_FILECOMPARE_FLUID_PROPERTIES/HT_EOS/FLUID_PROP (Failed)
TK_FILECOMPARE_H/sat_2D/H_sat_flow_K_ortho (Failed)
TK_LONG_FILECOMPARE_H/Theis_2D/Thies_quad_2d (Failed)
TK_FILECOMPARE_H/Theis/GWF_Theis_1-5D (Failed)
TK_FILECOMPARE_H/Theis/GWF_Theis_2-5D (Failed)
TK_FILECOMPARE_H/Theis/GWF_Theis_2D (Failed)
TK_FILECOMPARE_H/Theis/GWF_Theis_3D (Failed)
TK_FILECOMPARE_H/Theis/LF_Theis_1-5D (Failed)
TK_FILECOMPARE_H/Theis/LF_Theis_2-5D (Failed)
TK_FILECOMPARE_H/Theis/LF_Theis_2D (Failed)
TK_FILECOMPARE_H/Theis/LF_Theis_3D (Failed)
AKS_FILECOMPARE_GAS_FLOW/nonisothermal_gas_flow/h_gas_line (Failed)
HS_LONG_FILECOMPARE_C/diffusion/Diff_HTO_test (Failed)
BG_FILECOMPARE_ECLIPSE_DUMUX/2phase_flow_2phase_tracertransport/2pf_2pt (Failed)
BG_FILECOMPARE_ECLIPSE_DUMUX/2phase_flow_radialmodel/2pf_radialmodel (Failed)
2BG_FILECOMPARE_ECLIPSE_DUMUX/kinetic_CO2phase_generation_E100/CO2phase_gen_E100 (Failed)
BG_FILECOMPARE_ECLIPSE_DUMUX/kinetic_CO2phase_generation_E300/CO2phase_gen_E300 (Failed)
BG_FILECOMPARE_C/2d_Cl_transport_Clay/Nuklidtransport (Failed)
UJG_LONG_FILECOMPARE_M/creep/m_triax_lubby2 (Failed)
WX_LONG_FILECOMPARE_M/excavation/3D_Time_Controlled/3D_Excav_Time_Controlled (Failed)
WX_FILECOMPARE_M/3D_oedometer_mohr_coulomb (Failed)
HS_FILECOMPARE_C/calcite_gems/calcite (Failed)
WW_BENCHMARK_PETSc/h_tri/h_tri (Failed)
WW_FILECOMPARE_PETSc/h_tri/h_tri (Failed)
WW_FILECOMPARE_PETSc/McWhorter/mcwt (Failed)
WW_FILECOMPARE_PETSc/Richards/h_us_quad (Failed)
WW_FILECOMPARE_PETSc/T_tri/t_tri (Failed)
WW_FILECOMPARE_MPI/McWorther/mcwt (Failed)
However, I also tested the current trunk and I am getting the same failures.
Using my updated versions the ECLIPSE_DUMUX benchmarks should work fine (cross-checked on my own machine with the older versions of OGS with wich the coupling between OGS and Eclipse still worked).
So atleast those failures should cease to exist..
Unless there are any objections I would like to update the current trunk in the next few days. If there are objections just let me know.
Kindest regards & thanks again to Lars,
Tilmann Pfeiffer
Wolf Tilmann Pfeiffer
Geohydromodelling
Institute of Geoscience
Christian-Albrechts-University of Kiel
Ludewig-Meyn-Strasse 10, 24118 Kiel, Germany
phone: 0049 (0)431 880-4805
mail: [email protected]
