Dear OGS-developers,
I'd like to announce that the new version 5.4.04 (YS, WW, NW) is
released and the trunk is unlocked now. The release note can be find
here .
This version is
aimed mostly at random
walk particle tracking (RWPT) process. Several functions were
developed:
according to the coordinates of where particlesbeing injected, check and update element index information at
time step 0 (before the RWPT displacement calculation); -
add a so called “two-rate model” for thesorption-desorption process, which can be switched on by
adding a sub keyword “$APP_TYPE” in the pcs file and setting
the value as 2; -
clarify the property “identity” to state particlestatus (0 stands for particles that can move freely, 1 for
absorbed ones, and 2 for filtered ones); -
boundary control function was developed for 2Dand 3D cases that particles will stick to the boundary surface
when trying to escape from the calculation domain; -
add a property “on_boundary” to indicate particleposition (0 stands for particles not stuck on the boundary
surface, 1 for on the boundary); -
count the number of particles that pass through acertain point, which can be switched on by adding a sub
keyword “$COUNT” in the pcs file and setting the value as 1; -
RWPT can be coupled with different flowprocesses, for example, Forchheimer flow regime.
Four benchmarks
were added:
Existing one: Harter (1D advection-dispersionwith sorption-desorption and decay; count the number of
particles that pass through the outlet point and compare the
breakthrough curve with the analytical solution) -
Existing one: Veri1000 (2D rectangular domainwith particle cloud distribution under advection-dispersion;
compare the distribution curve with analytical solution) -
Added: HomoCube (a cube domain with tetrahedralmesh; homogeneous permeability)
Added: 2DGrains (2D rectangular domain withdiscretized grains inside; grains are belonged to different
material groups; particles diffuse into the grains) -
Added: 3DGrain (a cube domain with one graininside which shows as a void space, thus boundary control is
applied on both grain and domain surface) -
Added: Forchheimer (1D transient flow; count thenumber of particles that pass through the outlet point)
Yuanyuan
-- Yuanyuan Sun, PhD student
Building 7.2, room 205
Permoserstrasse 15, 04318 Leipzig
Tel.: +49(0)341 /235-1478
Email:
