We (Wenqing, Marc, me) has released a new version 5.5.6 (v5.5.5 was tagged for JOD's changes) including the following major changes.
* support parallel FEM with PETSc in coupled HM, H2M, and TH2M processes
* extend SELF_ADAPTIVE time control with new keywords MULTIPLIER, INI_TIME_STEP, ITR_TYPE, STAY
* add constrained BC/ST options with a new keyword $CONSTRAINED
* add RECHARGE and RECHARGE_DIRECT as $DIS_TYPE for ST
* add $PRESSURE_AS_HEAD keyword for BC to give hydraulic head as BC in PRESSURE based processes
For more details, please visit
https://svn.ufz.de/ogs/wiki/ReleaseNotes
Norihiro
Norihiro Watanabe, Dr.-Ing.
Wissenschaftler
Telefon +49 341 235 1806
Hi Norihiro,
I have a problem when I switch to 5.5.6 for the example abdulLab in COUPLED_FLOW. The example was running fine with 5.5.4. However, when I used the 5.5.6, it stopped without printting any results (see the screen output below). There must be something I should change in the abdulLab.num or some other input file to make it in 5.5.6, right? I would appreciate if you can help me go through the example abdulLab with 5.5.6.
Xuan
Screen output of abdulLab runing with 5.5.6:
Outer coupling loop 3/3 complete.
Max coupling error (relative to tolerance): 2.542e+000
This step is rejected: Redo, with a new time step.
Stop this simulation. New time step size is same as the rejected one
For process: OVERLAND_FLOW
No time control for this process.
Number of non-converged iterations: 0
Number of stagnated iterations: 0
For process: GROUNDWATER_FLOW
For process: RICHARDS_FLOW
GetRFProcessProcessingAndActivation - to be removed
^O^: Your simulation is terminated normally ^O^
Simulation time: 6s
On Monday, December 8, 2014 6:59:28 AM UTC-5, Norihiro Watanabe wrote:
tagged for JOD’s changes) including the following major changes.
- support parallel FEM with PETSc in coupled HM, H2M, and TH2M processes
- extend SELF_ADAPTIVE time control with new keywords MULTIPLIER,
- add constrained BC/ST options with a new keyword $CONSTRAINED
- add RECHARGE and RECHARGE_DIRECT as $DIS_TYPE for ST
- add $PRESSURE_AS_HEAD keyword for BC to give hydraulic head as BC in
Norihiro
Wissenschaftler
norihiro...@ufz.de / http://www.ufz.de
Dear Xuan,
please try with the following parameters to $OVERALL_COUPLING in abduLab.num
$OVERALL_COUPLING
; min iterations -- max iterations
1 25
Nori
On 01/06/2015 08:40 PM, Xuan Yu wrote:
Hi Norihiro,
5.5.6.
Xuan
Simulation time: 6s
processes
<https://svn.ufz.de/ogs/wiki/ReleaseNotes>
Norihiro
Wissenschaftler
norihiro...@ufz.de <javascript:> / http://www.ufz.de
Groups "ogs-users" group.
an email to ogs-users+unsubscribe@googlegroups.com
Wissenschaftler
Hi Nori,
Thank you very much. It worked.
Xuan
On Wednesday, January 7, 2015 5:00:15 AM UTC-5, Norihiro Watanabe wrote:
Dear Xuan,
$OVERALL_COUPLING
; min iterations – max iterations
1 25
Nori
Hi Norihiro,
5.5.6.
Xuan
Simulation time: 6s
processes
[https://svn.ufz.de/ogs/wiki/ReleaseNotes](https://svn.ufz.de/ogs/wiki/ReleaseNotes)
<[https://svn.ufz.de/ogs/wiki/ReleaseNotes](https://svn.ufz.de/ogs/wiki/ReleaseNotes)>
Norihiro
Wissenschaftler
norihiro...@ufz.de <javascript:> / [http://www.ufz.de](http://www.ufz.de)
Groups “ogs-users” group.
an email to ogs-users+...@googlegroups.com
mailto:ogs-users+...@googlegroups.com.
Wissenschaftler
