Version request 5.5.5
We (Wenqing/Marc/me) would like to release a new version 5.5.5 including the following major changes and bug fixes. If there is no objection, we will update trunk and announce the version in a few days.
Changes
- support parallel FEM with PETSc for modeling of coupled HM /H2M/ or TH2M processes
- add keyword "COUPLED" to SELF_ADAPTIVE time control
- add constrained BC/ST options
- add RECHARGE and RECHARGE_DIRECT as DIS_TYPE for ST
- give HEAD as BC in PRESSURE based process (PRESSURE_AS_HEAD)
- remove the break control because it may cause zombie processes on EVE
- check line ending of input files before start reading them
- enabled clock time output for all PCS
Bug fixes
- bugfix for transient Sugio approach
- bugfix in Marsily and Yaws(1976) Viscosity models
- correct fluid momentum velocity during local assembly if XZ coordinates
- correct MPFGetNodeValue for MASS_TRANSPORT
- correct DISTRIBUTE_VOLUME_FLUX if no node found
- no need to switch velocity dimensions for FLUID_MOMENTUM in PVD output
- fix issues in TIN file reading
Nori
Norihiro Watanabe, Dr.-Ing.
Wissenschaftler
[email protected] / http://www.ufz.de
Telefon +49 341 235 1806
