we (Thomas Nagel, me) would like to release a new version 5.6.0 including the following major changes and bug fixes. If there are no objections, we will update trunk and announce the version in a few days.
Since we added a new process "TES", which is a thermal equilibrium variant of the already existing TNEQ, the new OGS release will have version number 5.6.0 and not 5.5.8.
List of changes (github-PR#, committer, PR-description)
Changes
#167 by norihiro-w turn on MAT_NEW_NONZERO_ALLOCATION_ERR flag in PETSc
#144 by chleh added a namespace for physical constants
#137 by norihiro-w move all third party libs to ThirdParty
#142 by waltherm STABLE_ERROR_ADAPTIVE time stepping
#135 by wenqing Added prefix for command line PETSc options.
#134 by wenqing Enable RELOAD for PETSc#DEFORMATION.
#133 by waltherm add restriction for calculation of velocity for constrained BC/ST
#131 by bilke Remove all Qt and VTK dependent functionality incl. Data Explorer
#112 by chleh New process type TES
#111 by chleh added material model zeolite Z13XBF
#95 by chleh added commandline-parameter to specify the output directory
#87 by waltherm Stable Option for Constrained BC
Removal of numerous compiler warnings (nohiro-w, chleh)
Fixes
#166 by norihiro-w fix a bug that recalulation of time stepp doesn't work for Richards flows with regional local flow
#173 by chleh FIX: polyline found for empty name
#171 by wenqing Fixed a compilation error caused by pow function under VS2010
#146 by wenqing Enabled Mat***SetPreallocation for PETSc matrix again.
#159 by norihiro-w fix a bug that a rejected time step was not recalculated for PI_AUTO_STEP_SIZE
#143 by waltherm add time step rejection for nonlinear solver
#117 by wenqing Fixed a bug in constrained BC under MPI/PETSc.
#129 by norihiro-w need NEW_EQS for IPQC with MPI
Christoph Lehmann
I'm going to prepare the next OGS release (5.6.0) now. Please do not
change trunk until the release is done. I'll inform you about that.
hereby I announce the new release of OGS5 -- 5.6.0.
There are numerous changes---please find all of them them in the list
below---one of them being the addition of a new process type TES.
On Jenkins three benchmarks have been disabled:
* AKS_H_us_Wet_h_us_line_Forsyth
* AKS_H_us_Wet_h_us_line_Warrick
* AKS_H_us_Wet_h_us_tri_freebc
SVN trunk now is open again for your development.
Release Notes OpenGeoSys 5.6.0 (CL/TN) -- 7 July 2015
Changes
* Moved CMakeConfiguation and cmake directory to scripts/cmake.
* Turned on MAT_NEW_NONZERO_ALLOCATION_ERR flag in PETSc.
* Added a namespace for physical constants.
This namespace shall serve as a source of unified values for
physical constants in the future. Please use it for new developments.
* Moved all third party libraries to ThirdParty.
* Added STABLE_ERROR_ADAPTIVE time stepping.
* Added prefix for command line PETSc options.
* Enabled RELOAD for PETSc#DEFORMATION.
* Added restriction for calculation of velocity for constrained BC/ST.
* Removed all Qt and VTK dependent functionality including Data Explorer.
* Added a new process type TES, which is a thermal equilibrium version of TNEQ.
* Added material model for zeolite Z13XBF.
* Added commandline-parameter to specify the output directory: --output-directory=DIR
* Added STABLE Option for Constrained BC.
Removal of numerous compiler warnings.
Fixes
* Fixed: Bug in Stiff_Bulirsch-Stoer.
* Fixed: Recalulation of time step didn't work for Richards flows with regional local flow.
* Fixed: Polyline were found if empty line in gli file was given.
* Fixed: Compilation error caused by pow function under VS2010.
* Enabled Mat***SetPreallocation for PETSc matrix again.
* Fixed: Rejected time step was not recalculated for PI_AUTO_STEP_SIZE.
* Fixed: Added time step rejection for nonlinear solver.
* Fixed: Bug in constrained BC under MPI/PETSc.
* Fixed: Need NEW_EQS for IPQC with MPI.
Christoph Lehmann
