Version Request
I would like to check in a new version for the OGS-GEM coupling next week. The version will include the source code for the GEMS-Kernel (which requires some changes in the cmake files as GEMS libraries are obsolete), some bugfixes and improvements in the OGS-GEMS coupling, a new density model for calculating density driven flow with fluid densities from GEMS3K and updates in benchmarks.
If there are no objections I will close the trunk beginning of next week. Those who would like to preview the changes may have a look at the OGS-GEM branch.
Many greetings, Georg
Phone: +41-56-3104743 * Fax: +41-56-3102821
Email: [email protected] h323:+41563104743
homepage: Personenverzeichnis | PSI
Hoi,
trunk is closed....if everything works well, I will be finished latest
on Wednesday.
Greetings, Georg
On 25 Okt., 09:33, Georg Kosakowski <[email protected]> wrote:
OGS-GEM branch.
Email: georg.kosakow...@psi.ch h323:+41563104743
homepage:Personenverzeichnis | PSI
A fug that multiple applies some source term across different processes has been fixed. The trunk will be updated soon with the following commit if there is no objection.
  index d3af978..08801d7 100644
@@ -1095,6 +1095,9 @@ void CSourceTermGroup::Set(CRFProcess* m_pcs, const int ShiftInNodeVector,
        for (long i = 0; i < no_st; i++)
           CSourceTerm *source_term (st_vector[i]);
+ if(m_pcs->getProcessType() != source_term->getProcessType() )
+ continue;
           source_term->setSTVectorGroup(i);
  (note: it is a cherry-pick from gitgub repository)
