Version request
Dear OGS developers,
I'd like to make a small update of trunk in this week. Changes are only that a thermal expansion term is added to LIQUID_FLOW. I'll also provide one benchmark example. If there is no objection, I will update the trunk on Thursday.
Kind regards,
Norihiro
Norihiro Watanabe
Wissenschaftler
Helmholtz-Zentrum f�r Umweltforschung GmbH - UFZ
Permoserstra�e 15 / 04318 Leipzig / Germany
[email protected] / http://www.ufz.de
Telefon +49 341 235 1806
Wissenschaftlicher Gesch�ftsf�hrer: Prof. Dr. Georg Teutsch
Administrativer Gesch�ftsf�hrer: Dr. Heike Gra�mann
Dear Nori,
You have to update first because I committed some changes this morning.
Wenqing
Kind regards,
Norihiro
I want to update some output for groundwater model calibration / water balance in the trunk this week. If there are no objections I will close the trunk on Wednesday.
Kind regards,
Jens
2012/11/13 Wenqing Wang [email protected]
Dear Nori,
Wenqing
I’d like to make a small update of trunk in this week. Changes are only that a thermal expansion term is added to LIQUID_FLOW. I’ll also provide one benchmark example. If there is no objection, I will update the trunk on Thursday.
Kind regards,
Norihiro
Hoi Jens,
ich habe gerade noch einen "Fehler" in rf_time_new.cpp gefunden. Kannst du einen Bugfix mit in deine Version (release) einbauen?
Das Problem tritt auf, wenn man Richards_flow + andere Prozesse nicht vom Zeitpunkt t=0 started, also z.B. in der tim Datei
START_TIME
  1e9
setzt.
Bei mir tritt das bei Restart Rechnungen auf...
Da w�hrend der Initialisierung last_active_time = 0.0 gesetzt wird, wird in problem.cpp line 884
             m_tim->time_step_length = next_time - m_tim->last_active_time;
falsch berechnet :wink:
Ich schlage vor, in rf_time_new.cpp line 197 etwas einzuf�gen und last_active_time =time_start zu setzten...etwa so
         if(line_string.find("$TIME_START") != std::string::npos)
             line.str(GetLineFromFile1(tim_file));
             line >> time_start;
             last_active_time=time_start; //KG44: I would propose this
             line.clear();
             continue;
Herzlichen Dank, Georg
Phone: +41-56-3104743 * Fax: +41-56-3102821
Email: [email protected] h323:+41563104743
homepage: Personenverzeichnis | PSI
Oops, that is my fault I think, should have thought of that issue. Georg’s fix seems reasonable, and should take care of it.
On Tuesday, December 4, 2012, Georg Kosakowski wrote:
Hoi Jens,
ich habe gerade noch einen “Fehler” in rf_time_new.cpp gefunden. Kannst du einen Bugfix mit in deine Version (release) einbauen?
START_TIME
1e9
setzt.
Bei mir tritt das bei Restart Rechnungen auf…
Da während der Initialisierung last_active_time = 0.0 gesetzt wird, wird in problem.cpp line 884
Ich schlage vor, in rf_time_new.cpp line 197 etwas einzufügen und last_active_time =time_start zu setzten…etwa so
        line >> time_start;
        line.clear();
        continue;
homepage: http://people.web.psi.ch/kosakowski/
