What is the unit of the heatflow? @ Source term, heat_transport, temperature, constant_neumann.
Good evening ladies and gentlemen,
I’m working now extensively for some month with OGS to compare it with other numerical heat transport codes.
It’s cool.
However my temperatures are really low in my domain over all the time, I’m modelling density driven heatflow in porous media. In the other model I get higher temperatures in like 10%-20% range.
My suspicion is that the source term heatflow is differently handled.
my .st file
#SOURCE_TERM
HEAT_TRANSPORT
$PRIMARY_VARIABLE
TEMPERATURE1
$GEO_TYPE
POLYLINE Bottom_BC
$DIS_TYPE
CONSTANT_NEUMANN 0.1
Can someone tell me what unit the CONSTANT_NEUMANN condition for heat_transport in OGS has? And do I have to take the mesh(spatial discretization for FEM) into account?
MB
Dear Marius,
I am not sure if I remember it right, but I think the unit for CONSTANT_NEUMANN in terms of heat transport should be W/m in case of a Polyline (W/m2 in case of having a SURFACE). This means for you, that you are introducing 0.1 W/m of your Polyline and therefore the length of your Polyline is also important. OGS will then calculate a value for each node on your polyline itself. You can check your defined boundary conditions by setting the keyword $BOUNDARY_CONDITION_OUTPUT to your .pcs-file as shown in the example below:
#PROCESS
  HEAT_TRANSPORT
 $NUM_TYPE
  NEW
and run the simulation for the first time steps again.
Best regards
Steffi
Am 05.01.2016 um 21:28 schrieb Marius:
      I'm working now extensively for some month with OGS to compare it with other numerical heat transport codes.
It’s cool.
      However my temperatures are really low in my domain over all the time, I'm modelling density driven heatflow in porous media. In the other model I get higher temperatures in like 10%-20% range.
my .st file
#SOURCE_TERM
              HEAT_TRANSPORT
             $PRIMARY_VARIABLE
              TEMPERATURE1
             $GEO_TYPE
              POLYLINE Bottom_BC
             $DIS_TYPE
MB
Steffi Popp
  Institute of Geosciences
  Geohydromodelling
  Ludewig-Meyn-Str. 10
  24118 Kiel
  Germany
  Phone: +49 (0)431-880 1347
  Mobile: +49 (0)176-67373655
  E-Mail: Web:
[email protected]
http://www.geohydromodellierung.ifg.uni-kiel.de/en/team/m.sc.-steffi-popp
For the value of CONSTANT_NEUMANN for transport problems, its unit is
W/m^2 and it is value of heat flux density. In addition, you have to take care about temperature unit, which is a little bit mess in current OGS5 (it will be cleaned in future). If you use Kelvin as temperature unit in the material parameters, you have to choose Kelvin as temperature. Otherwise, Celsius has to be adopted.
It's cool.
my .st file
#SOURCE_TERM
  HEAT_TRANSPORT
$PRIMARY_VARIABLE
  TEMPERATURE1
$GEO_TYPE
  POLYLINE Bottom_BC
$DIS_TYPE
MB
"Celsius has to be adopted".--> "|||Celsius can be adopted|" |
>For the value of CONSTANT_NEUMANN for transport problems, its unit is W/m^2 and it is value of heat flux density. In addition, you have to take care about temperature unit, which is a little bit mess in current OGS5 (it will be cleaned in future). If you use Kelvin as temperature unit in the material parameters, you have to choose Kelvin as temperature. Otherwise, Celsius has to be adopted.
It's cool.
my .st file
#SOURCE_TERM
  HEAT_TRANSPORT
$PRIMARY_VARIABLE
  TEMPERATURE1
$GEO_TYPE
  POLYLINE Bottom_BC
$DIS_TYPE
MB
@Mrs. Popp thank you!
I can see now that at my bottom_polyline I only introduce temepratures of 2.5°C per node. This may help me a little bit.
@Mr. Wang
But when I use thermal parameters like specific_heat, thermal_conductivity and thermal_expansion, isn’t it
the same for celsius and for kelvin?
What other parameters I have to look after?
Thank you for the replies.
MB
Am Dienstag, 5. Januar 2016 21:28:08 UTC+1 schrieb Marius:
It’s cool.
my .st file
#SOURCE_TERM
HEAT_TRANSPORT
$PRIMARY_VARIABLE
TEMPERATURE1
$GEO_TYPE
POLYLINE Bottom_BC
$DIS_TYPE
MB
If you use constant specific_heat, thermal_conductivity and thermal_expansion, you can take either Kelvin or Celius.
@Mr. Wang
But when I use thermal parameters like specific_heat, thermal_conductivity and thermal_expansion, isn't it
MB
    It's cool.
    my .st file
    #SOURCE_TERM
      HEAT_TRANSPORT
     $PRIMARY_VARIABLE
      TEMPERATURE1
     $GEO_TYPE
      POLYLINE Bottom_BC
     $DIS_TYPE
    MB
when I activate the boundary condition output, I get the information that at my bottom line a temperature of 2.5°C is applied.
The top line is perfect, 18°C that is good. Also my initial condition for the whole domain with 18°C seems to be applied. But 2.5°C what is this? Is it more like a temperature that is introduced? Since it is a Heatflow …
#Dirchilet BC (from rectdq1_HEAT_TRANSPORT_BC_ST.asc.bc file)
#Total BC nodes 25
#Node index, name, x, y, z, value:
2 TEMPERATURE1 6.000000000000e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
3 TEMPERATURE1 0.000000000000e+000 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
30 TEMPERATURE1 5.749999999999e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
31 TEMPERATURE1 5.500000000000e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
32 TEMPERATURE1 5.249999999999e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
33 TEMPERATURE1 4.999999999999e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
34 TEMPERATURE1 4.750000000000e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
35 TEMPERATURE1 4.499999999999e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
36 TEMPERATURE1 4.249999999999e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
37 TEMPERATURE1 3.999999999999e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
38 TEMPERATURE1 3.749999999998e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
39 TEMPERATURE1 3.499999999998e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
40 TEMPERATURE1 3.250000000000e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
41 TEMPERATURE1 3.000000000002e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
42 TEMPERATURE1 2.750000000002e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
43 TEMPERATURE1 2.500000000002e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
44 TEMPERATURE1 2.250000000002e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
45 TEMPERATURE1 2.000000000001e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
46 TEMPERATURE1 1.750000000001e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
47 TEMPERATURE1 1.500000000001e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
48 TEMPERATURE1 1.250000000001e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
49 TEMPERATURE1 1.000000000001e+002 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
50 TEMPERATURE1 7.500000000005e+001 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
51 TEMPERATURE1 5.000000000004e+001 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
52 TEMPERATURE1 2.500000000002e+001 0.000000000000e+000 0.000000000000e+000 1.800000000000e+001
#Source term or Neumann BC (from rectdq1_HEAT_TRANSPORT_BC_ST.asc.st file)
#Total ST nodes 25
#Node index, x, y, z, name value:
0 TEMPERATURE1 0.000000000000e+000 0.000000000000e+000 -1.000000000000e+002 1.249999999997e+000
4 TEMPERATURE1 2.499999999995e+001 0.000000000000e+000 -1.000000000000e+002 2.499999999995e+000
5 TEMPERATURE1 4.999999999990e+001 0.000000000000e+000 -1.000000000000e+002 2.499999999996e+000
6 TEMPERATURE1 7.499999999986e+001 0.000000000000e+000 -1.000000000000e+002 2.499999999995e+000
7 TEMPERATURE1 9.999999999980e+001 0.000000000000e+000 -1.000000000000e+002 2.499999999994e+000
8 TEMPERATURE1 1.249999999997e+002 0.000000000000e+000 -1.000000000000e+002 2.499999999995e+000
9 TEMPERATURE1 1.499999999997e+002 0.000000000000e+000 -1.000000000000e+002 2.499999999995e+000
10 TEMPERATURE1 1.749999999996e+002 0.000000000000e+000 -1.000000000000e+002 2.499999999995e+000
11 TEMPERATURE1 1.999999999996e+002 0.000000000000e+000 -1.000000000000e+002 2.499999999995e+000
12 TEMPERATURE1 2.249999999995e+002 0.000000000000e+000 -1.000000000000e+002 2.499999999995e+000
13 TEMPERATURE1 2.499999999995e+002 0.000000000000e+000 -1.000000000000e+002 2.499999999991e+000
14 TEMPERATURE1 2.749999999994e+002 0.000000000000e+000 -1.000000000000e+002 2.499999999985e+000
15 TEMPERATURE1 2.999999999992e+002 0.000000000000e+000 -1.000000000000e+002 2.499999999994e+000
16 TEMPERATURE1 3.249999999992e+002 0.000000000000e+000 -1.000000000000e+002 2.500000000006e+000
17 TEMPERATURE1 3.499999999993e+002 0.000000000000e+000 -1.000000000000e+002 2.500000000007e+000
18 TEMPERATURE1 3.749999999994e+002 0.000000000000e+000 -1.000000000000e+002 2.500000000007e+000
19 TEMPERATURE1 3.999999999995e+002 0.000000000000e+000 -1.000000000000e+002 2.500000000007e+000
20 TEMPERATURE1 4.249999999995e+002 0.000000000000e+000 -1.000000000000e+002 2.500000000007e+000
21 TEMPERATURE1 4.499999999996e+002 0.000000000000e+000 -1.000000000000e+002 2.500000000006e+000
22 TEMPERATURE1 4.749999999997e+002 0.000000000000e+000 -1.000000000000e+002 2.500000000007e+000
23 TEMPERATURE1 4.999999999997e+002 0.000000000000e+000 -1.000000000000e+002 2.500000000006e+000
24 TEMPERATURE1 5.249999999998e+002 0.000000000000e+000 -1.000000000000e+002 2.500000000007e+000
25 TEMPERATURE1 5.499999999999e+002 0.000000000000e+000 -1.000000000000e+002 2.500000000008e+000
26 TEMPERATURE1 5.749999999999e+002 0.000000000000e+000 -1.000000000000e+002 2.500000000007e+000
1 TEMPERATURE1 6.000000000000e+002 0.000000000000e+000 -1.000000000000e+002 1.250000000003e+000
Am Dienstag, 5. Januar 2016 21:28:08 UTC+1 schrieb Marius Bittner:
It’s cool.
my .st file
#SOURCE_TERM
HEAT_TRANSPORT
$PRIMARY_VARIABLE
TEMPERATURE1
$GEO_TYPE
POLYLINE Bottom_BC
$DIS_TYPE
MB
Hello Marius,
as far as I understand it the 2.5 is just the value applied to the individual node (as you can see the nodes with less contact area to the model have lower values of 1.25). As it is a source term for heat transport the unit is not °C or K but should be W (Joule/s).
Marius Bittner schrieb:
Heatflow …
#Total BC nodes 25
0.000000 000000e+000 1.800000000000e+001
file)
#Total ST nodes 25
#Node index, x, y, z, name valu e:
-1.000000000000e+002 2.4999 99999995e+000
-1.000000 000000e+002 2.500000000007e+000
&n bsp; I’m working now extensively for some month with OGS to compare it
It's cool.
my .st file
#SOURCE_TERM
  HEAT_TRANSPORT
 $PRIMARY_VARIABLE
  TEMPERATURE1
 $GEO_TYPE
  POLYLINE Bottom_BC
 $DIS_TYPE
&n bsp; CONSTANT_NEUMANN 0.1
MB
Groups “ogs-users” group.
mailto:[email protected].
Oh and boundary conditions are obviously in °C or K…
Wolf Tilmann Pfeiffer schrieb:
Hello Marius,
Heatflow …
#Total BC nodes 25
36 TEMPERAT URE1 4.249999999999e+002 0.000000000000e+000
0.00 0000000000e+000 1.800000000000e+001
file)
#Total ST nodes 25
-1.000000000000e+0 02 1.249999999997e+000
13 TEMPERATURE1 2.49999 9999995e+002 0.000000000000e+000
-1.0000 00000000e+002 2.500000000007e+000
It’s cool.
time, I’m modelling density driven heatflow in porous m edia. In
my .st file
#SOURCE_TERM
HEAT_TRANSPORT
$PRIMARY_VARIABLE
TEMPERATURE1
$GEO_TYPE
POLYLINE Bottom_BC
$DIS_TYPE
MB
You rece ived this message because you are subscribed to the Google
Hi Marius,
as Tilmann already answered the value in the boundary output should be in W, as you used CONSTANT_NEUMANN (W/s) in the source term definition. As OGS calculates the value for each node with the given source term of 0.1 W/m, which you defined in the st. file, you get one value for each node on your polyline. The temperature you get in the model domain can than be seen in your outputfiles for paraview or tecplot for example.
The question is, which value do you want to define for your polyline? Which value did you define for the other numerical models you want to compare OGS with? You might have to be careful with the units defined in the other models for this line? Without any knowledge about the model setup it seems to be hard to help you with this problem.
Steffi
Am 06.01.2016 um 11:58 schrieb Wolf Tilmann Pfeiffer:
    Hello Marius,
      Heatflow ...
      #Total BC nodes 25
      file)
      #Total ST nodes 25
      &n bsp; I'm working now extensively for some month with OGS to compare it
      It's cool.
      time, I'm modelling density driven heatflow in porous m edia. In
      my .st file
      #SOURCE_TERM
      HEAT_TRANSPORT
      $PRIMARY_VARIABLE
      TEMPERATURE1
      $GEO_TYPE
      POLYLINE Bottom_BC
      $DIS_TYPE
      MB
      an email to . For more options, visit . -- You rece ived this message because you are subscribed to the Google Groups "ogs-users" group. To unsubscribe from this group and stop receiving emails from it, send an email to . For more options, visit . -- You received this message because you are subscribed to the Google Groups "ogs-users" group. To unsubscribe from this group and stop receiving emails from it, send an email to . For more options, visit .
Steffi Popp
  Geohydromodelling
  24118 Kiel
  Germany
  E-Mail: Web:
[email protected]
[email protected]
[email protected]
[email protected]
In the other model I set up a constant Heatflow with 0.1 J/ms.
The only obvious difference I can see is the mesh. But I did a mesh convergency and for all my OGS meshes the temperature is pretty low. I have no experience as well. I can’t tell if 0.1 J/ms at a bottom line in a 600x100 soil domain of 18°C has an impact at all.for now the max temperature I get is 19°C.
The other model gives me values around 25°C as max temperature.
Thank you for all your replies. I’ll mention the nice community in my report.
MB
It’s cool.
my .st file
#SOURCE_TERM
HEAT_TRANSPORT
$PRIMARY_VARIABLE
TEMPERATURE1
$GEO_TYPE
POLYLINE Bottom_BC
$DIS_TYPE
MB
There is now a webpage on some basic conventions like units of BCs and STs: OGS Conventions
