I went the approach to partition according to materials and IC's.
SUB_DOMAIN works fine with defining a constant values on each SUB_DOMAIN.
like this:
$GEO_TYPE
SUB_DOMAIN
2
0 2000
1 0
However, defining linear function such as
$GEO_TYPE
SUB_DOMAIN
2
0 2000.0+1000.0*x+0.0*y+0.0*z
1 0
does not work. The IC's are still 2000 on SUB_DOMAIN 0 and 0 on SUB_DOMAIN 1. I rearranged the positions of x, y, z but it did not improve. I use OGS 5.6.
Johannes
Am Donnerstag, 14. September 2017, 09:57:11 MESZ hat Wenqing Wang > <wenqing.wang@ufz.de> Folgendes geschrieben:
Maybe you can try
$DIS_TYPE
DIRECT file_foo
In the file_foo, you can put node wise values as
[node ID] [Node value]
Or you can partition the mesh groups taking account of both material and initial condition attributions. For example, a mesh is partitioned into four material groups:
group 0 and group 2 have the same material properties,
group 1 and group 3 have the same material properties,
groups 0, 1, 2, 3 have different initial conditions.
On 09/13/2017 08:23 PM, 'Johannes Boog' via ogs-users wrote:
Dear Wenqing,
thanks for your reply. Is there any other way then using different material groups?
I wanted to avoid that because I will define material groups according to the different materials (to be used in more complex model domains).
Johannes
Am Mittwoch, 13. September 2017, 18:26:31 MESZ hat Wenqing Wang >> <wenqing.wang@ufz.de> <mailto:wenqing.wang@ufz.de> Folgendes >> geschrieben:
You can do that by:
1. generate a mesh with element groups with different material IDs, which can represent the different zones with different ICs.
2. assign the initial condition to subdomains by the material IDs of element groups as
#INITIAL_CONDITION
[PCS type]
$PRIMARY_VARIABLE
[Primary variable name]
$DIS_TYPE
FUNCTION
$GEO_TYPE
SUBDOMAIN
[number of subdomains]
[Mat ID] a+b*x+c*y+d*z
where in the linear expression, a, b, c, d are input constants, + and * are operators, x,y,z are coordinate symbols. In the linear expression, any term except a can be omitted.
Examples:
1 =====================================
#INITIAL_CONDITION
MULTI_PHASE_FLOW
$PRIMARY_VARIABLE
PRESSURE2
$DIS_TYPE
FUNCTION
$GEO_TYPE
SUBDOMAIN
1
0 1.693567e5+-11559.45*z
2=====================================
#INITIAL_CONDITION
LIQUID_FLOW
$PRIMARY_VARIABLE
PRESSURE1
$DIS_TYPE
FUNCTION
$GEO_TYPE
SUBDOMAIN
2
0 1.693567e5+11559.45*y+-11559.45*z
1 1.693567e5+1559.45*z
#INITIAL_CONDITION
LIQUID_FLOW
$PRIMARY_VARIABLE
PRESSURE1
$DIS_TYPE
FUNCTION
$GEO_TYPE
SUBDOMAIN
2
0 1.693567e5
1 1.693567e5
On 09/13/2017 02:12 PM, 'Johannes Boog' via ogs-users wrote:
Dear OGS users,
I have a 3d model ( a cube) and would like to assign different IC on the upper and downer half of the DOMAIN.
I tried to define a volume for each half of the DOMAIN using #VOLUME in the *.gli file. That does not work, OGS does not read the defined VOLUMES.
I read about #SUB_DOMAIN to be used in *.ic in an older OGS manual. Is that keyword still active? I did not really got how it works from the manual. Does anybody has experience?
Johannes
To unsubscribe from this group and stop receiving emails from it, send an email to ogs-users+unsubscribe@googlegroups.com <mailto:ogs-users+unsubscribe@googlegroups.com>.
