Hello everyone,
I am getting a critical error while running a project with a parallel capability (Petsc) and simulation freeze after that. The output message is below:
This is the similar problem to Zhang Ning post in gitlab (Issue), where he said this could be solved after rebasing to latest development version but I am still getting this error.
Way to reproduce the problem
- Compile OGS (CC=mpicc CXX=mpic++ cmake -G Ninja -DOGS_USE_PETSC=ON -DOGS_USE_MFRONT=ON -DCMAKE_BUILD_TYPE=Release …/ogs)
- Run parallel model with GroupBasedParameter. (
3D_Trial_Model.zip (145.2 KB))
laxman@laxman-HP-15-Notebook-PC:~/build/bin$ mpirun -np 3 --oversubscribe ogs /home/laxman/Desktop/3D_Trial_Model/Trial.prj
info: This is OpenGeoSys-6 version 6.4.0-1036-gdd7be4565.
info: OGS started on 2021-09-05 04:26:20+0545.
[0] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/mesh …
[2] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/mesh …
[1] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/mesh …
[0] warning: Could not open file ‘/home/laxman/Desktop/3D_Trial_Model/mesh_partitioned_node_properties_cfg3.bin’.
You can ignore this warning if the mesh does not contain node-wise property data.
[0] info: [time] Reading the mesh took 0.009408 s.
[0] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/bottom …
[0] info: [time] Reading the mesh took 0.002045 s.
[0] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/top …
[0] info: [time] Reading the mesh took 0.004421 s.
[0] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/X0 …
[2] warning: Could not open file ‘/home/laxman/Desktop/3D_Trial_Model/mesh_partitioned_node_properties_cfg3.bin’.
[2] info: [time] Reading the mesh took 0.008598 s.
[2] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/bottom …
[2] info: [time] Reading the mesh took 0.002107 s.
[2] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/top …
[2] info: [time] Reading the mesh took 0.004363 s.
[2] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/X0 …
[1] warning: Could not open file ‘/home/laxman/Desktop/3D_Trial_Model/mesh_partitioned_node_properties_cfg3.bin’.
[1] info: [time] Reading the mesh took 0.008915 s.
[1] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/bottom …
[1] info: [time] Reading the mesh took 0.001971 s.
[1] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/top …
[1] info: [time] Reading the mesh took 0.004542 s.
[1] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/X0 …
[2] info: [time] Reading the mesh took 0.002246 s.
[1] info: [time] Reading the mesh took 0.002230 s.
[0] info: [time] Reading the mesh took 0.002268 s.
[2] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/X1 …
[1] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/X1 …
[0] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/X1 …
[0] info: [time] Reading the mesh took 0.002067 s.
[2] info: [time] Reading the mesh took 0.002204 s.
[1] info: [time] Reading the mesh took 0.002219 s.
[1] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/Z0 …
[0] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/Z0 …
[2] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/Z0 …
[0] info: [time] Reading the mesh took 0.001971 s.
[1] info: [time] Reading the mesh took 0.002064 s.
[2] info: [time] Reading the mesh took 0.002108 s.
[0] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/Z1 …
[2] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/Z1 …
[1] info: Reading corresponding part of mesh data from binary file /home/laxman/Desktop/3D_Trial_Model/Z1 …
[2] info: [time] Reading the mesh took 0.002065 s.
[1] info: [time] Reading the mesh took 0.002122 s.
[0] info: [time] Reading the mesh took 0.002364 s.
[2] info: GroupBasedParameter: YoungModulus
[1] info: GroupBasedParameter: YoungModulus
[1] critical: /home/laxman/ogs/ParameterLib/GroupBasedParameter.cpp:76 createGroupBasedParameter()
[2] critical: /home/laxman/ogs/ParameterLib/GroupBasedParameter.cpp:76 createGroupBasedParameter()
[0] info: GroupBasedParameter: YoungModulus
[0] info: GroupBasedParameter: PoissonRatio
[0] info: GroupBasedParameter: Cohesion
[0] info: GroupBasedParameter: FrictionAngle
[0] info: GroupBasedParameter: DilatancyAngle
[0] info: GroupBasedParameter: TransitionAngle
[0] info: GroupBasedParameter: TensionCutOffParameter
[0] info: ConstantParameter: displacement0
[0] info: ConstantParameter: dirichlet0
[0] info: FunctionParameter: p0
[0] info: ConstantParameter: Rainfall
[0] info: No source terms for process variable ‘displacement’ found.
[0] info: No source terms for process variable ‘pressure’ found.
[0] info: ### MFRONT ########################################################
[0] info: Behaviour:MohrCoulombAbboSloan'. [0] info: Hypothesis:Tridimensional’.
[0] info: Source:MohrCoulombAbboSloan.mfront'. [0] info: TFEL version:3.4.2-dev’.
[0] info: Behaviour type:STANDARDSTRAINBASEDBEHAVIOUR'. [0] info: Kinematic:SMALLSTRAINKINEMATIC’.
[0] info: Symmetry:ISOTROPIC'. [0] info: #Mat. props.: 7 (array size 7). [0] info: --> typeSCALAR’ with nameYoungModulus', size 1, offset 0. [0] info: --> typeSCALAR’ with namePoissonRatio', size 1, offset 1. [0] info: --> typeSCALAR’ with nameCohesion', size 1, offset 2. [0] info: --> typeSCALAR’ with nameFrictionAngle', size 1, offset 3. [0] info: --> typeSCALAR’ with nameDilatancyAngle', size 1, offset 4. [0] info: --> typeSCALAR’ with nameTransitionAngle', size 1, offset 5. [0] info: --> typeSCALAR’ with nameTensionCutOffParameter', size 1, offset 6. [0] info: #Gradients: 1 (array size 6). [0] info: --> typeSTENSOR’ with nameStrain', size 6, offset 0. [0] info: #Thdyn. forces: 1 (array size 6). [0] info: --> typeSTENSOR’ with nameStress', size 6, offset 0. [0] info: #Int. StVars.: 2 (array size 7). [0] info: --> typeSTENSOR’ with nameElasticStrain', size 6, offset 0. [0] info: --> typeSCALAR’ with nameEquivalentPlasticStrain', size 1, offset 6. [0] info: #Ext. StVars.: 1 (array size 1). [0] info: --> typeSCALAR’ with nameTemperature', size 1, offset 0. [0] info: #Real-valued parameters: 8. [0] info: --> with nameRelativeValueForTheEquivalentStressLowerBoundDefinition’.
[0] info: → with nametheta'. [0] info: --> with nameepsilon’.
[0] info: → with namepi'. [0] info: --> with namelocal_zero_tolerance’.
[0] info: → with nameminimal_time_step_scaling_factor'. [0] info: --> with namemaximal_time_step_scaling_factor’.
[0] info: → with namenumerical_jacobian_epsilon'. [0] info: #Integer parameters: 0. [0] info: #Unsigned parameters: 1. [0] info: --> with nameiterMax’.
[0] info: Using OGS parameterYoungModulus' for material propertyYoungModulus’.
[0] info: Using OGS parameterPoissonRatio' for material propertyPoissonRatio’.
[0] info: Using OGS parameterCohesion' for material propertyCohesion’.
[0] info: Using OGS parameterFrictionAngle' for material propertyFrictionAngle’.
[0] info: Using OGS parameterDilatancyAngle' for material propertyDilatancyAngle’.
[0] info: Using OGS parameterTransitionAngle' for material propertyTransitionAngle’.
[0] info: Using OGS parameterTensionCutOffParameter' for material propertyTensionCutOffParameter’.
[0] info: ### MFRONT END ####################################################
