Dear colleagues,
I am running a case using Richards_flow. A coupled 2D and 3D mesh should simulate fault zone and rock mass.
Now is my problem (see attached file):
The newest version V5.5 is quite problematically concerning the calculated inflow rate and distribution (page 2).
The V5.4 supplies also questionable velocity distribution (page 3).
If I run only 3D without 2D fault. The pressure and velocity distribution look acceptable (page 4), similar to those from Groundwater_flow (page 1).
Does anyone have experience on it and can give me some suggestions.
Thanks in advance.
Hua
OGS_1.pdf (324 KB)
Hi Hua,
I had a similar problem last year with the liquid flow module. What are your numerical settings and the permeability difference.
Increasing the accuracy of the linear solver might help. You might look up the discussion on the mailing list from last year.
Greetings, Georg
-----Original Message-----
From: ogs-users@googlegroups.com on behalf of Shao, Hua
Sent: Wed 10/8/2014 10:21 AM
To: ogs-users@googlegroups.com; ogs-devs@googlegroups.com; ogs6@googlegroups.com; Mailingliste opengeosys@ufz.de
Subject: [ogs-users] OGS Richards_Flow
Dear colleagues,
1. The newest version V5.5 is quite problematically concerning the calculated inflow rate and distribution (page 2).
2. The V5.4 supplies also questionable velocity distribution (page 3).
3. If I run only 3D without 2D fault. The pressure and velocity distribution look acceptable (page 4), similar to those from Groundwater_flow (page 1).
Thanks in advance.
Hua
Hi Hua,
How did you set the fault permeability in your MMP file? Giving permeability in local coordinates of the fault (i.e. permeability along the fault) is supported only in Liquid flow and Groundwater flow. For other processes such as Richards flow, you need to provide a permeability tensor in global coordinates.
You can also modify the code to support it in Richards flow. The coordinate transformation for liquid and groundwater flow is done in CalCoefLaplace() in fem_ele_std.cpp. You need to copy lines below "if (dim > MediaProp->geo_dimension)" to the Richards flow part.
Nori
On 10/08/2014 10:21 AM, Shao, Hua wrote:
Dear colleagues,
1.The newest version V5.5 is quite problematically concerning the
2.The V5.4 supplies also questionable velocity distribution (page 3).
3.If I run only 3D without 2D fault. The pressure and velocity
Thanks in advance.
Hua
Norihiro Watanabe, Dr.-Ing.
Wissenschaftler
Telefon +49 341 235 1806
Thank you Nori & Wenqing. I changed the dimension to 3 for my fault in the Richards flow model, the velocity is now correct. The question is then my definition about area will be used or ignored?
I have now another oscillation problem with mass transport for my big 3D fault/matrix model (110 K elements with all tri, tet, quad, prima elements, which length varied fro, 1 meter to 50 meters). I have varied delta t, dispersion length ... without success.
Have any one (CAU-colleague) idea, which parameter can be used for the stable solution in the mass transport?
Hua
-----Ursprüngliche Nachricht-----
Von: ogs-users@googlegroups.com [mailto:ogs-users@googlegroups.com] Im Auftrag von Wenqing Wang
Gesendet: Mittwoch, 8. Oktober 2014 13:48
An: ogs-users@googlegroups.com
Betreff: Re: [ogs-users] OGS Richards_Flow
Right.
On 08.10.2014 13:44, Norihiro Watanabe wrote:
Hi Hua,
Nori
Dear colleagues,
Thanks in advance.
Hua
The area value given in mmp is used in calculation.
Hua
Right.
Hi Hua,
Nori
Dear colleagues,
Thanks in advance.
Hua
