Good day! Best wished for the new year.
I have a question about the input format of OGS.
Question background:
The input files what I have are: (1) .prj (2) all required .vtu (defined the boundaries, bulk, etc.)
My question is: how to generate a heterogeneous field of my input? for example, the permeability field.
Currently, in my case, the permeability defined in .prj is a constant.
One easy possibility would be to use paraview to generate an additional data array, for instance with the name HeterogenousPermeabilityParameter, in your bulk mesh.
Second step: In the project file you can specify a parameter within the <parameters> section of type MeshElement as follows
