Dear Luyu,
First step: Generate the data for the parameter
- One easy possibility would be to use paraview to generate an additional data array, for instance with the name
HeterogenousPermeabilityParameter, in your bulk mesh.
Second step: In the project file you can specify a parameter within the <parameters> section of type MeshElement as follows
<parameter>
<name>HeterogenousPermeabilityParameter</name>
<type>MeshElement</type>
<field_name>DataArrayNameInBulkMesh</field_name>
</parameter>
Third step: Use this parameter in the description of the permeability within the <medium>-tag as follows:
<property>
<name>permeability</name>
<type>Parameter</type>
<parameter_name>HeterogenousPermeabilityParameter</parameter_name>
</property>
There are also benchmarks available using this feature, see for example inhomogeneous_permeability.prj
Best regards,
Tom
