Reg. the creation of a mesh file for the reactive domain
Dear Sir,
For the reactive transport coupled with PHREEQC, I want to create a mesh file (.vtu) with bulk_node_ids and bulk_element_ids.
But, I couldn’t produce such a .vtu file with both bulk_node_ids and bulk_element_ids from the .msh file generated from Gmsh. I used msh2vtu to do so.
Please let me know how to create a .vtu file with both bulk_node_ids and bulk_element_ids for the reactive domain through the command lines.
I am attaching the files for your reference.
Thanks
Pavan.
KineticReactant2_2d.zip (712.1 KB)
Check the answer given here
Dear lurpi,
I know how to convert .vtu from .msh files using msh2vtu command. But, my question is specifically about generating a .vtu file that has bulk_node_ids and bulk_element_ids.
Anyhow I even tried the command that you suggested GMSH2OGS, but couldn’t fulfil my requirement.
Let me know how to create such a file.
Thanks
Pavan.
use the OGS tool identifySubdomains
identifySubdomains -m mesh.vtu -o numbered_ mesh.vtu
then you obtain a numbered_mesh.vtu with what you need .
See Identify subdomains in bulk mesh. for further informations.
Dear lurpi,
I could notice that the identifySubdomains command creates a boundary mesh with bulk_node_ids and bulk_element_ids. But, in my case, I need those ids for the entire domain not just for the boundaries.
Please go to Tests/Data/Parabolic/ComponentTransport/ReactiveTransport, and you can see that all the examples in that folder needed a reactive domain mesh file. I need to generate a similar mesh file that has all the ids (bulk_node_ids and bulk_element_ids).
Thanks
Pavan.
In the command
replace ‘mesh.vtu’ with whatever vtu you need to process. A domain is a subdomain of itself, it will work.
Thanks, Lurpi. It worked.
I have another question, how to assign a random distribution of material parameters to the mesh (e.g., porosity and permeability)?
I have no direct experience. Check
as well as the publication https://www.sciencedirect.com/science/article/pii/S136516092100263X
I suggest you to open a different question, related to the definition of random fields: OGS: [case] RandomFieldMeshElementParameter
