I compared analytical solution as presented in Page 308 (Equation 14.18-14.20) with the OGS result as available in the Benchmark Reference. The comparisons results are not same as it is in Figure 14.12 (Page 310). In the Benchmark Result Reference, it is also observed that the temperature is not changing along the radial direction, while it is evident in Figure 14.12.
The benchmark of TM_axi is a steady state problem. However the specific heat capacity is set to non-zero in the input files. I have corrected the input files, and updated the repositories of input data and reference results. Please checkout the current master branch of https://github.com/ufz/ogs5-benchmarks.git for the corrected input files of TM_axi.
Wenqing
On 11/06/2017 10:09 PM, Mohammad Islam wrote:
Hi All,
I was running one benchmark solution on Thermoelastic Deformation in a Hollow Cylinder. The reference is available as follows
Kolditz et al (2010) "Thermo-Hydro-MechanicalChemical Processes in Fractured Porous Media: Benchmarks and Examples ", Chapter 14, Page 307 Springer.
I have one more quick question. In Kolditz et al. (2010) draft version (OpenGeoSys Developer-Benchmark- Book OGS-DBB 5.04 (Chapter 15, Page 323)), for the analytical solution there is a reference Wang II, (2007) . However, on that draft or in Kolditz et al (2010), Wang II, (2007) reference is missing. I am wondering is there any way to inform the reference source? I also checked Timoshenko and Goodier (1970), Yu (2000) and couple of more text books.
Timoshenko, S.P., Goodier, J.N., 1970. Theory of Elasticity, third ed. McGraw Hill Education.
Yu, H.-S. (2000). Cavity Expansion Methods in Geomechanics, Springer.
Could you please send me the page in the draft version that you mentioned?
On 11/07/2017 05:20 PM, Mohammad Islam wrote:
Dear Wenqing Wang,
Thank you very much. It solved the problem.
Dear Wenqing Wang,
Kolditz et al (2010) "Thermo-Hydro- MechanicalChemical Processes in Fractured Porous Media: Benchmarks and Examples ", Chapter 14, Page 307 Springer.
Thanks in advance.
To unsubscribe from this group and stop receiving emails from it, send an email to ogs-users+...@googlegroups.com.
Got it. The reference is one of my programming notes about the solution that I obtained for the example, and it was removed because of it is not an official publication . You can found it in the attachment.
Dear Wenqing Wang,
Most likely there is a typo mistake, either in Kolditz et al. (2010) or in your notes. Please check Chapter 14, Page 308-309 and compare with your notes. I have also attached a comparison. The summary are as follows
Kolditz et al. (2010) equation 14.18 & your note equation 7, one negative sign is missing.
Kolditz et al. (2010) equation 14.19 & your note equation 8, “r” is missing.
With Kolditz et al. (2010) equation 14.19 and boundary condition, the expression of equation 14.22 is not correct. The first part ln(R2/r) should be ln(R2/R1). In addition, if 14.19 is correct, then there will be R1 in the 2nd and third part. In fourth part, there will be positive sign than negative sign. The bottom 2nd part R1^2 should be replaced with R2^2.
With Kolditz et al. (2010) equation 14.18, 14.19 and 14.22, the obtained analytical solution don’t match with OGS results.
Dear Wenqing Wang,
1) Kolditz et al. (2010) equation 14.18 & your note equation 7, one negative sign is missing.
2) Kolditz et al. (2010) equation 14.19 & your note equation 8, "r" is missing.
3) With Kolditz et al. (2010) equation 14.19 and boundary condition, the expression of equation 14.22 is not correct. The first part ln(R2/r) should be ln(R2/R1). In addition, if 14.19 is correct, then there will be R1 in the 2nd and third part. In fourth part, there will be positive sign than negative sign. The bottom 2nd part R1^2 should be replaced with R2^2.
With Kolditz et al. (2010) equation 14.18, 14.19 and 14.22, the obtained analytical solution don't match with OGS results.
On Wednesday, 8 November 2017 09:33:32 UTC-5, Mohammad Islam wrote:
Dear Wenqing Wang,
Thank you again for your kind help.
Dear Wenqing,
Here is the revised one. I have changed the initial condition file too. Most likely, the domain initial condition is not correct. The Analytical solution match if it is zero. In your note, equations 7 and 8 are right one. But in Kolditz et al. (2010) there are couple of typo mistakes in equations 14.18, 14.19 and 14.21. The boundary conditions in your note and Kolditz et al. (2010) are different. Therefore, the integral constants expressions are different. If possible, in your note before equation 5, please include the equilibrium equation general form. Moreover, in between equation 4 and 5 in your note, there are also typo mistake, the Poisson ratio symbol need to be replaced with the Shear Modulus symbol.
On Tuesday, 14 November 2017 04:07:25 UTC-5, Wenqing Wang wrote:
Dear Mohammad,
Thanks for checking. I will check it again.
Wenqing
On 11/13/2017 09:09 PM, Mohammad Islam wrote:
Dear Wenqing Wang,
Dear Wenqing Wang,
Thanks. I have found the problem in the input files (as you mentioned T0=0), and updated the benchmark repository yesterday. I will add a documentation to the repository about an erratum to the equations today.
Wenqing
On 11/16/2017 10:29 PM, Mohammad Islam wrote:
Dear Wenqing,
Thanks in advance.
Dear Mohammad,
Wenqing
Dear Wenqing Wang,
"r" is missing.
Dear Wenqing Wang,
Yesterday, I also prepared a C++ code about the analytical solution of TM_axi in my repository:
Dear Wenqing,
Thanks in advance.
Dear Mohammad,
Wenqing
Dear Wenqing Wang,
"r" is missing.
Dear Wenqing Wang,
I have updated the benchmark repository by adding the analytical solution data, tecplot layouts, and a PDF (sort of erratum) as that attached. In my note, there is no Poisson ratio symbol, and I use nu (mu is better) for shear modulus, which is explained in the text. Of course nu normally stands for Poisson ratio. Thanks for point out this.
Dear Wenqing,
Thanks in advance.
Dear Mohammad,
Wenqing
Dear Wenqing Wang,
"r" is missing.
Dear Wenqing Wang,
Just changed a few words in my notes just for your information:
1. lines between eqn(2) and eqn (3),
2. nu --> mu
3. add the momentum balance equation.
Note: It is for an old benchmarks of ogs5, and TM_axi is based on it.
Dear Wenqing,
Thanks in advance.
Dear Mohammad,
Wenqing
Dear Wenqing Wang,
"r" is missing.
Dear Wenqing Wang,
Dear Wenqing,
Thank you very much. One more typo mistake in TM_axi.pdf. In your code ( Line Number 36:(lambda + phi) / (R2 *R2))), but in equation 14.22 (lambda + phi) / (R1 *R1)).
On Friday, 17 November 2017 06:35:38 UTC-5, Wenqing Wang wrote:
Dear Mohammad,
Thanks for your checking again.
Wenqing
Dear Wenqing,
Thanks in advance.
Dear Mohammad,
Wenqing
Dear Wenqing Wang,
Dear Wenqing Wang,
On Friday, 17 November 2017 09:40:32 UTC-5, Mohammad Islam wrote:
Dear Wenqing,
But in equation 14.21 ,
A0 = -2. * K * (log(R2) - 0.5) - 2. * A1 / (R2 * R2)
Dear Wenqing,
On Friday, 17 November 2017 10:10:58 UTC-5, Wenqing Wang wrote:
What in my source code is correct. The PDF for the benchmark has already been updated again. See
[https://github.com/ufz/ogs5-benchmarks/blob/master/TM/TM_axi.pdf](https://github.com/ufz/ogs5-benchmarks/blob/master/TM/TM_axi.pdf)
Thanks Mohammad!
